DAC AD1862: Almost THT, I2S input, NOS, R-2R
Hi guys and gals.
I've asked in Ian's thread but to no avail so I ask here about 'snaps' and 'pops' between tracks. Using Ian's Fifo with both XOs populated. Rpi set to no oversampling. I get awful pops and snaps between tracks. I fear for the tweeters.
If I force an oversample to use just one clock it's the same.
Any advice on this?
Hi, I want to build the PCM63P dac version. I will be feeding it with a WIIM pro that only has coaxial and spdif outputs. Any suggestions on what board for the IS2 convertor? The JLsounds board is usb only from what I can see. So I need a board that accepts coaxial or Spdif and will work with the PCM63P dac. Thanks
Thank you zoom777. I cant find that model on ebay so looking for a solution there. Would this work? Do the LED screens cause any kind of interference or noise problems? Is the WM8805 better than the ak4118.
https://www.ebay.ca/itm/166424359358
That adapter was whipped up specifically to properly convert the dual OPA1656 opamp for single opamp usage. Since then the single OPA1655 was released, just use a standard SOIC8 to DIP8 adapter and no additional parts are needed.
But, I believe the resistors are 0805 size and the cap is 0603. Just double check that with the supporting documentation in this thread.
Reactions: audiosteve
Hello fellow DAC builders,
I have need of a 2 genuine AD1862 N chips. I have a PM into one member who had some for sale awhile ago, but would like to ask here if anyone here in the US or Canada would have a spare pair. Thank you for your consideration.
MM
Reactions: Mobes123
