D3a Russian equivalent recommendation
The translation says "more charm than a 300B". You cannot quantify the sound by "charm".
Personally I can only deal with measurements, it is my limitation. I cannot judge how an amplifier sounds to a particular person. Also, youtube sound is not a reference, to say the least.
I have 4p1l PP sound ok but not polite as 45SE
Many shop in china clone Kt88 inexpensive. There are plenty of KT88 pp or SE sell in many E-commerce and used market. What i listen to KT88 PP, i did not like. Load of bass not my style
Yes, a push-pull KT88 will give you plenty of bass if you use decent output transformer. You probably want a single ended amplifier, plenty of those also in Aliexpress.
This chinese guy make 811 833 and many
He still not mention to avoid 811
In contrary he support more info
811阴极电流等于屏流和栅流之和,栅流越大,输出的屏流就越小,栅流越小,输出的屏流就越大。把811栅极的正偏置设在参数的中间,并严格控制工作时进入负栅区,这样的输出波形比栅极忽左忽右时的输出波形要好得多。不过说实话,此时的波形也是不对称的,尽管管子工作在正栅区,栅流也会随着输入信号正负半周的变化而造成输出屏流的变化—负半周时削顶小,正半周时削顶大,只不过此时比栅压忽左忽右时要好而已。这就是所说的左派功放管做单端功放绕不过的坎。
I'd recommend translating text in Chinese, the forum formal language is English.
About the 811A. I have my opinion, based on what I see and the curves. I have never used one, therefore you can take what I say with a grain (or a tablespoon) of salt 😀
