The F5Pi -- F5P Voltage Gain Stage + M2 Output Stage = Perfectly Integrated
It is finally done -- an integrated amplifier using a F5 frontend and the M2OPS.
Patrick
  • F5Pi Description 231128 Public.pdf
Reactions: 18 users
A lot of the credit goes to the Alpha tester, who does most of the building.
I was told that he was very happy with the sound.
But I'll let him tell you the details when he has more time.
Also most sincere thanks to Jan Didden for helping with the many rounds of distortion measurements.
Patrick
Reactions: 8 users
The Alpha tester is not a xen Team member.
He is a good friend and an experienced DIY'er.
I want to have someone whom I trust can execute the build to a high standard.
But who is still independent, so that he is completely free to post any comments or listening impressions, positive and negative.
The audition was also done with other DIY friends nearby him, and compared with other DIY amps.
So hopefully it should be as "objective" as it can be.
But give him time.
Was already a stressful weekend for him to get it finished. :geek:
Patrick
Joined 2004
Amazing result as always Patrick and congratulations to the Alpha tester as well! Well done!
It's quite clear that a massive amount of work and prep went into this and I'm sure we only see the path taken and not all the effort that went into the abandoned trials along the way.
Looking forward to the listening impressions from the tester and his lucky friends :)
Stephen
Reactions: 1 users
To answer a couple of questions :
The prototype was build using all Toshiba devices, i.e. K170/J74, K2013/J313, and K3497/J618.
The first two pairs are standard on Pass Labs products and many DIY projects.
Some says that it is another project using unobtainiums.
But if you look around, components for analogue, especially for audio, are disappearing day by day.
That is now not only limited to transistors, but also to other devices, both active and passive.
All the Nichicon Audio Capacitors are End of Life.
There are essentially next to no low-noise JFETs in production except for switching.
So in a few years, either you can only use Class D chips, or buy NOS devices while they are still available.
Stock up while you can, unless of course you are happy to build with ICs, whether analogue chipamps or Class D.
Bear in mind that a Class A Power Amp Heatsink Enclosure will easily set you back 300€.
An audio grade toroidal transformer another 100€.
How much do you think should be spent on the sonic-defining active devices ?
But for those who have a limited budget and still want to join the fun, the circuit is flexible enough to accommodate alternative devices.
It will at the expense of some additional distortion.
Here are some alternative configurations :
Input JFETs
2SK246BL / 2SJ103BL, as in Jean-Marc Planeteve’s Zenquito, with some resistor value changes
2N5457 / 5460 and their SMD version, obsolete but still can be found, resistor value changes
TO220 MOSFETs
FQP3N30 / 3P20, obsolete but available at Rochester, requires 5V extra for front end PSU.
IRF610 / 9610, also requires 5V extra for front end PS.
Output MOSFETs
IRFP240 / 9240, results in earlier clipping due to higher Vgs at bias.
Patrick
Reactions: 3 users
This is really a fantastic project. Congratulations to all builders and testers. The construction has been thought through down to the smallest detail and looks superb. I am very impressed by the measurement results.
My monoblock is already impatiently waiting for new components. I think it is ideal for two stereo channels and will not have to feel abused.
But I would only build it as an integrated amplifier F5P frontend + M2OPS powerful stage and PS.
Is it planned to make the PCBs of F5P + M2OPS available here?
That would be a really lovely Christmas cookies:xmasman:
Reactions: 1 user
