A60(+) Amplifier. Build this?
Let me expose Madness of the European Union Economy:
Below is a snapshot of the shopping card for 20 pcs. 2SA1943 At Reichelt (Germany, Europe). They don't even have 2SC5200 on stock.
For comparison, there is a snapshot of the shopping card at Mouser.
Let's compare:
€5.59 each
Mouser (Texas, USA)
€2.16 each
Reichelt charge 159% more for the same products.
In addition to that, Mouser is blazingly fast. From Texas to Paris shipment takes 1-2 days and then UPS delivers a nice package to my doorstep in just 2 days.
In contrast, Reichelt takes time first to prepare shipment and then they slowly deliver in 6-9 days by DPD (German Packet Service)
Try this at CONRAD. I followed the price of a tweeter, their prices are dynamic. Start low and ends high and ar as slow as Reichelt. :headbash: Reichelt is most of the times cheaper.
Reactions: Berlusconi
Wow that's very kind of you. Thank you very much. Think I maybe should build it as dual mono.
But wait a little bit. Some transistors aren't available. I have several options including one built completely from available trustworthy components (ON Semi). I have already done this but later I have replaced some transistors with CDIL products. I think I have all necessary components to do that again.
I plan to first build one chanel for testing.
Thanks Marcel,
I used to purchase from both Conrad and Reichelt, but Farnell/UK and Mouser/USA are way better and have everything on stock, are fast, and cheaper too. Also, German companies in general arent what they once used to be.
Thanks Berlusconi! Please notice a change in the original schematic, as I noticed a double annotation. (Two resistors)
The schematic that corresponds with the BOM is here.
Thanks @m0rten ,
I think it is the right time to edit the Opening Post and add important stuff there. This scheme along with the BOM should be at the prominent place.
Now, look at the attached table below with parameters of 2SA970 and KSA992. It appears that all transistors can be replaced with these from reliable sources. I am not saying that the existing CDIL are bad but I prefer verified components.
Therefore, I plan to perform the following substitutions:
2SA1145 -> KSA1381
2SA970 -> KSA992
2SC2240 -> KSC1845
2SC2705 -> KSC3503
2SD669 -> KSC2690
Somewhere, I've heard that KSC2690 is used as output coupled thermal regulator in marantz 2245 and 2270. Otherwise, I have an alternative UTC produced 2SD669.
I will report later on on the success/failure of these replacements.
Here is the m0rtens BOM from post #642 , in plain view
Component Count:98
RefValueRefValueRefValue
C1220pR11KR2510R
C210uR222KR2610R
C31uR3470RR2710R
C41uR4470RR2810R
C530pR575RR2910R
C630pR675RR3010R
C7100nR71KR310R22
C8100nR81KR320R22
C9100nR947RR330R22
C10100nR1047RR340R22
C11470uR11220RR350R22
C12470uR12220RR360R22
C13100nR1333KR374R7
C141uR1433KR38475K
C151uR15470RR39475K
C16100uR16470RR401K2
C17100uR172K2R412K2
D11N4148R182K2R422K2
D21N4148R1915KR4375K
D31N4148R2015KR444K7
D41N4148R21680RRF11K
D51N4148R22100R/2WRF233R
D61N4148R2333R
Z112VR2433RP15K
Z212V
J1INJ2A1+40V-65V
J3OUTJ2B1-40V-65V
RefValueDatasheet
Q12SA970http://www.datasheetcatalog.org/datasheet/toshiba/905.pdf
Q22SC2240https://media.digikey.com/pdf/Data Sheets/Toshiba PDFs/2SC1815.pdf
Q32SA970http://www.datasheetcatalog.org/datasheet/toshiba/905.pdf
Q42SC2240https://media.digikey.com/pdf/Data Sheets/Toshiba PDFs/2SC1815.pdf
Q52SC2240https://media.digikey.com/pdf/Data Sheets/Toshiba PDFs/2SC1815.pdf
Q62SA970http://www.datasheetcatalog.org/datasheet/toshiba/905.pdf
Q72SA970http://www.datasheetcatalog.org/datasheet/toshiba/905.pdf
Q82SA1145http://www.datasheetcatalog.org/datasheet/toshiba/905.pdf
Q92SA970http://www.datasheetcatalog.org/datasheet/toshiba/905.pdf
Q102SC2705https://media.digikey.com/pdf/Data Sheets/Toshiba PDFs/2SC1815.pdf
Q112SC2240https://media.digikey.com/pdf/Data Sheets/Toshiba PDFs/2SC1815.pdf
Q122SC2240https://media.digikey.com/pdf/Data Sheets/Toshiba PDFs/2SC1815.pdf
Q132SD669http://pdf.datasheetcatalog.com/datasheet/sanyo/ds_pdf_e/2SB631.pdf
Q14MJE15034http://www.st.com/resource/en/datasheet/2sd1047.pdf
Q15MJE15035http://skory.gylcomp.hu/alkatresz/2SB817.pdf
Q16NJW0281http://www.st.com/resource/en/datasheet/2sd1047.pdf
Q17NJW0281http://www.st.com/resource/en/datasheet/2sd1047.pdf
Q18NJW0281http://www.st.com/resource/en/datasheet/2sd1047.pdf
Q19NJW0302http://skory.gylcomp.hu/alkatresz/2SB817.pdf
Q20NJW0302http://skory.gylcomp.hu/alkatresz/2SB817.pdf
Q21NJW0302http://skory.gylcomp.hu/alkatresz/2SB817.pdf
U1OP07https://www.analog.com/media/en/technical-documentation/data-sheets/OP07.pdf
Hello everyone. Question to our experts. Is it possible to install the A60+ board in a separate case horizontally (2 monoblocks), placing the output stage transistors on the right and left on separate radiators? Will the thermal conditions change significantly? There is only one small temperature stabilization transistor and will be located on one radiator. Of course, all this is connected to each other on a thick chassis. What are your opinions?🙄
I made a relay switch with a remote control to compare 2 amplifiers with switching to one acoustic system. After warming up, blind listening to Dartzeel and A60, 4 people (I’m on fast switching). Cardas interconnect cables, for speakers Kimber Cable 12TC, for the switch all homemade braided 4,2mm section. No winner identified. 2 votes for A60, 2 for Dartzeel. Everyone noted a small difference only in the middle. A60 is brighter, Dartzeel is softer. The only difference is in the connection. Dartzeel played through a pre-Krell with a relay volume control, A60 from the same, but only with a volume control since it has 2 switching outputs with and without pre .The volume is the same. Now I can safely recommend both for production, Dartzeel requires the highest quality components and a good power supply. All the best to everyone.
Hi, It is possible if you have a good thermal conduction between the 2 radiators like a mono bloc radiator or a thick Alu plate (5mm) to fix the radiators. You should place the thermal sensor transistor strategically between the 2 radiators to sensor an average heat dissipation. I think it could be better than one radiator.
Cool the test 😉
Hi all. I haven't written for a long time. I struggled with the sound of this A-60 for a long time. In the process of setting up and listening, I encountered a problem. Long to describe. The long-awaited, expected sound appeared only after bypassing UPC1237 on the board. There is a proposal to cut off everything connected with this protection and move it outside the board.
Hello everyone. Has anyone seen this and who is the manufacturer?
I have seen them here in Delhi, some people using them, they do it because most of the Toshiba print most often found to be Fake or Chinese reprinted as Toshiba 2SC5200/2SA1943
These ones are from Chinese Manufacturer directly, and they have their own logo as Jilin Sino company,
They said to be considered good enough, I plan to make use of them in my upcoming A60 , I bought these 4 following transistors
2SC5200/2SA1943
2SC4793/2SA1837
Here is a link for teardown of these transistors, Mind the language, it's not in English, it's Hindi language
Have you design PCBs, I like to see, I'm currently looking for a nice amplifier to make, I plan to make my own PCBs design, I need reference design, I gone through this whole thread, and find only PCB design from AliExpress PCBs, not any other,
Have you made your own design or just bought the PCBs and drawn the schematic from it.
Is there any difference between your schematic and PCBs actual schematic
Anyway thank for your schematic,
another thing ,which one is better MA-9S2 clone or A60/A60+
here most of you liked A60
