Why the objectivists will never win!
No, you’ll have a shared experience…..nothing more. Subtle variance in the shape of the outer ear will place individual frequencies in different places in a 3D space. The differences in our posture and reflections from our shoulders to our ears including variances in our clothing will do the same. In the moment physical state such as PB, heart rate, fatigue and in the moment temperament will also induce different responses to stimuli. Yes, as individual variance, each is subtle…..but when combined (as they often are) can be profound IF the listener is focused and attentive to the task.
And let’s not forget the room…..shared experience comparisons in different 3D spaces is a complete and utter waste of effort.…..visit a professional studio mixdown or mastering control room and you’ll understand why.…… 90% of the folks who have dedicated 2 channel systems are better off with a good set of headphones.
Then you have just created an absolute dead-end mathematical condition with no way out.
So why to continue?
P. S.: Anyway, thanks for your polite and appreciated way of posting. 👍
If stereo mike and DAT recorder can accurately capture the soundstage at recording stage why not re-record the soundstage at reproduction stage.
This was meant for those claiming to hear differences in soundstage between devices.
If you've been to concert halls or studios etc, you would have seen the various types of room correction equipment used to take account of peculiarities in that volumes sound. This I would say clearly infers (hopefully objectively) that spaces have a particular sound signature and that it might need adjustment in relation to some comparitor or standard. It would also mean that this effect is discernible. That means that the only point at issue then left is whether or not those sound differences can be recorded in such a way as to be repeatable when replayed via a system of some type in another space. Having been able to record, quantify and adjust sounds in the process of this to me at least points to it being noticeable when replayed.
I also have a Iasca competition CD, that has several tracks to test the soundstage's correctness.
My CD is no longer available, but it has a successor thay may be even better.
Hans
Finally, something useful from this thread. 😀
TIDAL has first two tracks available and quick listening confirms that this comparison between, by sound engineer intended instrument and artists positions and perceived by listening is very informative.
When talking mathematically, just try to find and concentrate on the overlapping areas and the show can go on.
Okay.
Then, if possible, I'd like to know your thoughts on the following without beating around the bush if possible (given my respect for you):
Then you have just created a dead-end condition with no way out.
So why to continue?
P. S.: However, it seems that not many people have fun playing in the "show" you mentioned.
I took one of my big commercial amps down to a dealer in Surrey about 3 or 4 yrs ago. They hooked it up to a very expensive pair of American speakers. It sounded absolutely awful. They guy apologised and said hf hadn’t run the speakers in yet. I was gutted, but I knew the amp sounded good because it had been played on B&W, KEF’s and an assortment of Graham models.
When I went back to collect it a week or two later, he said, ‘very nice amp, but have you got something more expensive?’
At the time it was a 6 grand amp.
I took one of my big commercial amps down to a dealer in Surrey about 3 or 4 yrs ago. They hooked it up to a very expensive pair of American speakers. It sounded absolutely awful. They guy apologised and said hf hadn’t run the speakers in yet. I was gutted, but I knew the smp sounded good because it had been played on B&W, KEF’s and an assortment of Graham models.
Maybe you should have returned after painting it gold and asked him for £10K
Reactions: Bonsai
And yes I know I should see someone about that...
Quite the opposite. I recall a member's comments in a thread about about 2-channel stereo's ability to create height. He adamantly insisted it is 'impossible in principle because humans are incapable of hearing height at all'. To his credit he retracted after asking his daughter to make overhead noises but reaching adulthood without conscious overhead localisation still boggles. It also indicated to me the extent to which localisation can be as much a honed skill as innate. Hearing changes in orchestral layout is no cause for apology.
AES NY 2023 will have numerous presentations on localisation, for example: Spatial resolution of human hearing with different azimuth, elevation and bandwidth of source signals.
Thanks for the interview you posted even though it's almost 30 years ago and talks about speaker design (that he does without ever listening to them).
In what when it was done (how long ago) is of importance? I mean when something is true, it's true whenever it was discovered years ago or this morning.
It hurts subjectivism beliefs when they read he designed loudspeakers without listening to them. Of course it is some kind of provocation: if you read again the interview and read between lines you'll see it's not totally true ( and it was confirmed by other speach Dunlavy did): do you really think when working with classical musicians ( Boston Symphonic Orchestra) he leave the room? 😉
Even Beethoven seems to have composed his music while being deaf, yet this - however extraordinary - proves nothing.
They are exceptional exceptions, but little else.
Mixing technical's requirements with artistic's one is a false 'short circuit' for reproduction chain.
Both are differents fields with differents requirements. I track it to the 'provocation': one need to get a reference to something he think can explain what hurts his feeling/beliefs and deaf compositors comes to mind. But in no way the capability to picture music in one mind ( and arrangement and interactions between instruments family) and being able to transcribe it ( write it) have anything to do with accuracy in reproducing, which wass Dunlavy's goal.
The fact is that even if you were an objectivist you are instead a subjectivist when you listen to your system and in fact the designer you mentioned declares himself an objectivist and never listens to the speakers he himself designs. 😳
Please note that I'm not looking for absolute technological value that has no correspondence with the senses, and therefore I'm not looking for technology that bypasses the use of the senses.
I'm an extremely sensual person instead.
This is where you make assumption and in my view didn't get what Dunlavy explained: -for his own design goal- he defined through measurement AND by listening test ( Why he worked with an acoustic orchestra...)- a SET OF CLEARLY DEFINED MEASUREMENTS RESULTS* which was constantly ranked BY LISTENING TEST as SUBJECTIVELY ACCURATE by him and musicians.
In my view you can't be more into sensual perception than with musicians as listeners as they seek for the sound of their instruments to be reproduced without alteration.
* it's the part in the interview where he explain his goal with step response, the study he made of anechoic chamber loudspeaker and instrument analysis.
Do you want a small treat?
I recently read that regarding quantum physics it seems that certain smells are heard more than they are smelled.
And it would therefore seem that good hearing capabilities are also predictive of a good sense of smell.
Don't ask me for references that I can't find at the moment...
Thanks again for the link, but in this circumstance a swallow did not make a summer.
In what it is a treat? Senses and how our brain react to them can somewhat be interleaved ( why synesthesya can be experimented so often when taking hallucinogen, or Trance induced behaviour through repetitive beats,...). In what it should be anything related to your point regarding subjectivism, i don't get it.
My turn: do you know you 'hear' very high frequency ( above 20khz) through the vibrations your eyes experiences? Do you know you experiment very low end more trough your bones (skeleton but internal organs too) than your ears?
I don't see a dichotomiy between what i feel and the explanation of the mechanism involved to explain what i felt.
Actually rather than confused I am intrigued by some comments in there on the accent mics they talk about left-right panning but nothing about adjusting for depth illusion, which infers from a sample of one forum they don't consider it a problem.
Bill
It may have skipped your attention, there is a link at the bottom of my post.
Navigate through it 😉
George
We can certainly feel some sound. This is not surprising considering the physical nature of sound.
Beethoven was deaf, yet he wrote and played music that endures to this day. He could "hear" the piano by holding a wooden stick in his mouth and pressing it against the piano. This suggests that he could have benefited from hearing aids or implants like what's available today.
I had clicked the link at the bottom but was just horrified at the triffids surrounding those poor innocent musicians. I think that website would drive me mad, but a great resource.
The difference between animals and humans is that the latter can somehow change their own program
I commented on this earlier. Medical research has been putting quantitative research together on helping people reprogram their brains. Currently MDMA and Psilocybin with theripists to tease out the programming that causes PTSD and depression. As more is learned what people “treat” will expend.
People have been informally doing this since time memorial, but for many here the explosion in brain reprogramming was really first seen during the cultural revolution of the ‘60s, as mainstream glommed onto very powerful mind altering substances (alo tof LSD). Many of us have personal experience.
dave
Reactions: Logon
