Why the objectivists will never win!
swinging back round to imaging again, which in my mind is mainly affected by (in no real order)
-what was encoded on the source.
-speakers
-room interactions (reflection, diffraction, absorbtion etc)
-The wet squishy collection of neurons processing it all
Now I have mentioned many times that a CD I enjoy using for checking all is good with my system (confession it rarely is. Small children and ribbons do not go well together) is Redbird https://en.wikipedia.org/wiki/Redbird_(Redbird_album). This is 4 people, with stringed instruments sitting around a stereo mike with a DAT recorder and apparantly having way too much fun. I love it for the non-musical sounds. The hum of the DAT recorder motor, sound of cars and dogs outside. It's as pure a recording as you get outside bluegrass BUT what should the soundstage be? Should 2 singers be behind you, or one sitting on top of the other? That part I can't work out, despite you being almost able to guess where the window is in the living room they were recording in. What I do know is that if one of the singers is coming from outside the speakers something must be wrong as they weren't sitting that far apart! Not sure collectively we have enough recordings where we know what it should sound like as references so are left guessing, and possibly guessing wrong.
So to the question. If someone were to come up with a suitable recording where the captured soundstage were known and people could map out what they heard where then compare with what they should get for a figure of imaging merit, would that be an objective test... And no AudioPrecision equipment involved!
I'm not sure what you mean by objective test. The fourth point in your list (the squishy) makes it subjective anyhow. Forgetting that squishy point what's wrong with just recording the soundstage with a mic and using difference analyzing SW when comparing devices? If you think stereo mike and DAT recorder can capture the soundstage what's keeping you from repeating the process at reproduction?
Nature recordists attempt this when experimenting with mic arrays, walking circumferences in regular intervals calling out degrees.
See I would love something like that as a locked track on a classical music CD where someone is walking around the stage calling out where they are as a reference. I used to get very confused listening to some of the mercury living presence recordings until I discovered the orchestra layout was done differently in those days!
And yes I know I should see someone about that...
George, you never confuse things. I know classical mike techniques vary from just 2 channels to whole trees. I think the BBC fly around 60 microphones for the proms each year as they need to do stereo and TV surround mixes for many types of music, but they never say what the final soundfield is supposed to be!
I also have a Iasca competition CD, that has several tracks to test the soundstage's correctness.
My CD is no longer available, but it has a successor thay may be even better.
Hans
We have the most powerful Signal processor between our ears unfortunately we have no way to calibrate it to a standard. So we try to come up with a measurement process to compare, however out technology has not reached a point that truly engulfs the listening experience.
I totally agree with this, but the brain is already calibrated to its own evolutionary "standard".
Put two healthy and cultured people under the exact same conditions to listen to the same system and the same track and they will hear the same thing.
But it can still be very enjoyable
dave
Agreed, and having fun is the most important thing. 😍
It is the search for the absolute - that does not exist - that creates so many useless conflicts.
On the path of science we should adopt humble, not arrogant attitudes, otherwise we never learn.
And they (the arrogant) are the same that only want to pretend to teach! 😉
@Hans Polak that looks really useful, but what does 'the sound is fat and should be democratically spread' mean?
You are the real artist with words, so when you don’t even understand, don’t ask me 🤣
As a matter of fact, if you like I could send these tracks via a Dropbox link, as I did with the previous Stereophile track.
Just let me know.
Hans
Reactions: TNT and jotom750
dave
Yes it is Dave…….but the landscape is changing fast. The death of the retail record company business had unintended consequence…..the loss of artistic and cutting edge production. Now we’re all left bathing in a sea of redundant, meaningless content that’s consumed like popcorn……..nobody ever looks or eats a single kernel…..they just inhale the stuff for a chew…..something to alleviate the boredom and momentary hunger.
Learning can sometimes be painful.
As true as it is simply human.
In one way or another the average human experiences are similar, subject to the necessary and obvious exceptions for better or for worse.
What really changes is in the qualities of the single people.
There are the humble and the arrogant.
The wise men and the braggarts.
The greedy and the balanced.
And all the different and related consequences.
IMO
We can sometimes be like the dung beetle, rolling a big ball of what we think is true around until it’s bigger than we are.
Possible, but please note the fact is that for the "dung beetle", doing what it does has its absolute dignity: there is no bad and no good in what it does.
The issue arises if/when personal interests come into play because then there are those who in that case people do not collaborate, but rather deliberately sabotage.
It also depends on what other qualities they have.
IMO
I very much doubt this thesis.
Even assuming the unlikely probability that all their hearing sensors (not only ears but also other pressure sensitive parts of the body) are transmitting the same info to their brains, but how and to what result their brains are processing this all is highly unlikely the same, already given the simple fact that no two brains are physically the same.
Hans
Reactions: krivium
Actually rather than confused I am intrigued by some comments in there on the accent mics they talk about left-right panning but nothing about adjusting for depth illusion, which infers from a sample of one forum they don't consider it a problem.
Just let me know.
I'm going on the hunt for that sheffield labs CD for my collection!
This discussion is making me want to start playing with mid-side processing for stereo width control.
No, you’ll have a shared experience…..nothing more. Subtle variance in the shape of the outer ear will place individual frequencies in different places in a 3D space. The differences in our posture and reflections from our shoulders to our ears including variances in our clothing will do the same. In the moment physical state such as PB, heart rate, fatigue and in the moment temperament will also induce different responses to stimuli. Yes, as individual variance, each is subtle…..but when combined (as they often are) can be profound IF the listener is focused and attentive to the task.
And let’s not forget the room…..shared experience comparisons in different 3D spaces is a complete and utter waste of effort.…..visit a professional studio mixdown or mastering control room and you’ll understand why.…… 90% of the folks who have dedicated 2 channel systems are better off with a good set of headphones.
