Extending Life Expectancy of Power Amp Tubes like EL34 by which kind of Switch-On Variants - which one is most useful ?
There is also the issue of the positive temperature coefficient of the resistance of the heater.
And here it is compared to a 7R resister, done on a much earlier spreadsheet,
not MS Excel. Think I was curious enough 20 yrs ago to run this. In general tube
heater resistance of several different types seemed to vary about 10X from cold to hot.
Reactions: gupsta
Although the Radiotron Hd/Bk 4th ed does mention near the beginning a description on voltage variations on tube life, it doesn´t provide any graphs. The graphic model I dug out nearly 30 yrs ago highlights the varying heater voltage on tube life, but the variation of anode load is not nearly so damaging .My approach with AC transformers is to have multiple incremental taps on the primary to deal with this.
However, the real problem in the early TV days was the series heaters using a ballast baretter with no input transformer was the worst of all conditions. No isolated chassis to the user, it was also mighty dangerous.
With low impedance european mains networks the C speed utility switchboard relays would immediately flip out with the slow (T) fuse approach. In my power amps of 500W upwards, on the primary side I always use a relay switching out a ballast resistor after 5-7 secs. This enables a fuse rating far more appropriate to the actual power.
Reactions: gupsta
I have a related question if it's okay to ask here. It would be nice to add a circuit which counts the power on time (usage) in hours and perhaps also the number of power on/off cycles. Does this type circuit have a name. Perhaps there are some commercial pcb/ kits available which can be added, but I couldn't find anything on the web, but I may be searching for the wrong name. If someone could point me in the right direction that would be appreciated.
gupsta, such information may help you appreciate when to either swap your output tubes, or otherwise do some performance checking (ie. that everything is operating as expected), but otherwise would have no tangible benefit I would suggest.
Certainly run hour meters are quite common.
Meaningful statistics from such a use meter would need many many many people doing the same, and then some power statistical and analytic investigation to see if any reliable view could then be formed, given the wide range of gear being monitored. If you used say an amp that at least tens of others also used, and were ok to monitor, and you gave everyone a new set of valves of the same maker/model/year then that may make any assessment easier, but would take quite some time.
gupsta,
If you have an amplifier that is killing tubes quickly, or earlier than you think they should . . .
Tell us how approximately how many hours the tubes have been run.
Then you should:
Consider finding or making a complete and accurate schematic, and making measurements of voltages and currents; marking those on the schematic, then posting them here.
Perhaps someone will be able to see if one or more tube's maximum specifications are being violated.
Also:
If the output tubes are self biased, or have a current sense resistor in the cathode, you might want to check them, then check again in 3 months, and if there is little or no change, then chack again in a year.
Check how hot the tubes run, whether they are stuck in a corner without much air flow, etc.
Think about what you do to keep your car running smoothly, and not stop working.
Just a few things to think about.
Reactions: tubetvr
As hour meter there is some models avalable https://www.ebay.com/itm/3644373489...M/S6zE8VtAvmf39i9znnhEGg==|tkp:Bk9SR4Tj0IzYYg
