Class D amp issue/need advice
This would be my option:
https://www.audiophonics.fr/en/powe...1.html?search_query=Purifi 600&fast_search=fs
Not expensive (only 582 euros excluding tax), monoblocks, proper binding posts (I use spades and banana plugs), reliable builds and most importantly... the amp/buffer IC is socketed DIL8 & the Vcc/Vee regs are 3-pin through-hole. Just by trying different regs and OPAmp, the sound could be fine-tuned to my liking/rest of my system.
@Nisbeth
Hi there! Yes I did use a good thermal paste on the bottom of the module before I mounted it to the bottom of chassis. I have read on another icepower module 50ASX2 that had kind of the same thing my module is doing. One guy mentions he tried lowering the voltage on variac to like 90 volts, and that seemed to fix the issue. Another guy mentions the voltage measurement weren't correct on two of the pins he measured and also it seems that a resistor had went south. This resistor going bad happened on quite a few of those models by icepower. I'm not sure if that is the case with mine though? I imagine I could use my DMM and try to see what kind of reading I could get by probing around. The only issue is my eyes are not so good anymore, and these are smd resistors. Any ideas would be appreciated! Thanks
I don't think its a rip-off. 30.000$ power cables are, not this amp kit....
I just told you whats inside. They literally charge 700e for the case. It is a serious rip off. There are manufacturers that charge waaaaay less. Even with custom input buffer, proper binding posts, it costs the same/less. VTV offers custom buffer, WBT-0703Cu NextGen binding posts, for the same money, in the same case. Apollon audio, 1090e, with custom input board and ofc binding posts... So yes, as said, soundimports ripoff...
https://www.audiophonics.fr/en/power-amplifier/audiophonics-mpa-m400et-power-amplifier-class-d-mono-purifi-1et400a-1x400w-4-ohm-p-14951.html?search_query=Purifi 600&fast_search=fs
These are the ones I have bought after calculating price and efforts of an own built. These are very good amps and I like them a lot.
All the best
Mattes
I even disconnected and reconnected the connections that connect to various plug-ins. I then tried it again and it worked for a while, then started doing the same thing. This seems a little crazy to me as I did it once again by unplugging the unit for a day or so, then plugged it back in and it stayed working good for a longer time, but now it's starting to act up again?? I have no idea why! Perhaps someone may know of a solution, as I really don't want to trash it? Any help would be greatly appreciated! Thanks!
That suggests a problem with the connections to P102. I have no practical experience with the 1200AS2. Disconnect P102. The amp should run normally without interruption, correct? According to the manual p 27 "If the module controls are left unconnected, the module will start normal operation without
further action."
There could be a problem with the trigger sense circuit in the amplifier, or the wiring to the trigger sense circuit. I am suggesting to remove the P102 header (gently heat the plastic and pry loose, then desolder individual pins) and solder control wires directly to the PCB (I think the most fool proof method). Other options are to solder new contacts to the wires, crimp new contacts to the wires or get a new (better) P102 harness.
@hifiamps
OK I see now what you are saying. I've already tried disconnecting the connector from P101 that has the jumper from pins 3 and 6 I believe. That didn't work, so I can try disconnecting the connector from P102 and see what happens. When I first built my amp kit, I wanted to use (2) separate LEDS amber for standby mode and blue for ON. It was working fine for a few years, then it started doing this switching from ON to Standby. It would then work fine for a while after this, but would then begin the same problem. I'll try disconnecting the connector on P102 and let you know what happens. I have read also where others had issues like me, but with another icepower module. They mentioned lowering the voltage to around 90V using a variac worked? I was going to try that as well, but first I'll just disconnect bot connectors on P101 and P102 to see if it continues. Thanks for your info!
