Which Class-D amp to get from Aliexpress?
Have recently acquired a new pair of all-weather speakers. apart mask 4 to be exact and seems that my previous board is just not fit for them (attached the one i have). Looking forward on your advice for an amp which has an aux and a Bluetooth connection (hard time deciding on the source of audio) which can pump the speakers up, The amplifier will be set in a hard to reach place with the only option to reset the power if smthing goes wrong
The specs are like impendence of either 8 or 16 (different sources) at 60w
It could be that O-Noorus also is a sub brand of the same factory that produces these devices under various names. They have similarities and advertising also has similarities.
The question is if they use output filters.
Some pics of the O-Noorus PA-70 (1 x MA12070) details.
I'm wondering about the performance of the dual chip design vs single.
Do you think they will sound much different or just a little more power?
I have 96db efficient speakers so the max power isn't so important, but should there be much difference in bass response/impact, imaging etc., due to the dual chip design?
Power spec's of O-Noorus MA12070 amps on Audiophonics:
PA-70 2x55W @ 4Ω, 1% THD (single chip)
OA36S 2x65W @ 4Ω, 1% THD (dual chip)
PA80 2x80W @ 4Ω, 2x45W @ 8Ω (dual chip)
Sadly they don't have any pics of the PA80 internals. Below is the OA36S.
One obvious difference I see is the WiFi chips used in the PA-70 vs the OA36S
  • o-noorus-oa36s-amplifier-class-d-2x-ma12070-bluetooth-50-2x65w-4-ohm (1).jpg
The PA80 uses this NJW1194 chip for tone and volume control.
You DIY guys have an opinion on this versus the PA-70 manual/physical tone controls?
which amp looks like it has better 1) likely better sound and value, 2) mod potential?
I'm guessing the tone controls could be bypassed in the PA-70 if desired and not in the PA80?
I can not see any coils. Are they on the backside?
Good question. I vaguely remember someone mentioning that the speakers' voice-coils can act as this (part of the circuit) but I'm note sure.
Btw, @jean-paul commented on filtering here: https://www.diyaudio.com/community/threads/infineon-ma12070-class-d.347422/post-7164883
the Chi-Fi design rule is to make the filters as cheap as possible so underrated parts, minuscule ferrite beads or the usual ... no filter at all. A coil + caps = good. A ferrite bead + caps = adequate. A single air coil = mmmmm but better than nothing. Nothing at all = not OK. Selection criterium for an MA12070 amplifier is to pick one with any form of filtering. No filtering is bad choice.
The absence of filtering is tolerated on short HP cable links, beyond that the HP cables behave like an RF antenna...
I would also be afraid of burning out the tweeters because of the high PWM frequencies that they could absorb if the crossover doesn't do its job.
This is why the output filters heat up on class D amps, they absorb unwanted high frequencies, so imagine the poor tweeter coil... 🧐 🧐 🧐
Reactions: 1 user
