This: https://www.dibirama.altervista.org...3-audax-tw025a2-tweeter-1-4-ohm-110-wmax.html
Or this: https://www.dibirama.altervista.org...-audax-tw025a26-tweeter-1-8-ohm-200-wmax.html
Or maybe this: https://www.dibirama.altervista.org...9-seas-27tffc-tweeter-1-6-ohm-200-wmax-2.html this is the TFF version, not the TFFC.
Why not an 1” compression driver with suitable waveguide? That will give the headroom you’re looking for.
Did you consider sica?
Not tested personally, but maybe just what you are looking for:
https://sica.it/prodotto/lp-111-25-245-tw/
Toutlehautparleur in france even offers 4 ohm versions with elevated sensitivity.
I found experimentally that the audax 25mm dome is too small diameter to match the opening of the Visaton waveguide. It has a cancellation around 12Khz. I'd say it was a great suggestion until I tried it. I found that an SB Acoustics Satori T29R gives good response, requires a 50mm o-ring to make a seal with the horn opening which is easy to implement.This: https://www.dibirama.altervista.org...3-audax-tw025a2-tweeter-1-4-ohm-110-wmax.html
I am interested, can you give mores informations about the usage of this horn on the T29R and photos please ?
How about the Audax TW034, which can be adapted to the WG148 with a smaller flange? The TW034 will do 94dB/2.83V on its own and even more with a stacked extra magnet. It sounds great too.
The Seas T35C002 also does 95dB/2.83V and can be crossed around 2k with ease, handling alot of power. Distortion is very low. You can push it very hard and adapt it the WG148 for even higher output levels.
The Audax TW025A28 is a potent 25mm dome that can play very loud. Its around 93 - 94 dB/2.83V without WG and adapts easily to a WG thanks to its flat faceplate.
First I apologize these measurements are sloppy. They were not done in ideal conditions = no baffle, microphone fairly close to horn because at further distances there's diffraction.Hi,
The TW29R faceplate is not flat, it has a very slightly conical profile which means it doesn't make contact with the waveguide in the center where the dome is, it only contacts at the outer edges. So I had to find a way to seal it.
The curves below are with the SB Acoustics TW29R Satori mounted on a Visaton WG148R waveguide, using modeling clay to make the seal between the tweeter and the waveguide:
I have attempted to also give you ~45 degrees off axis response but I can't be sure the distance to the microphone was consistent.
This is the same thing but with a 3.5mm thick x 50mm inside diameter rubber o-ring, instead of modeling clay:
Same disclaimers apply. The 45 degrees off axis is sloppy and I'm not at all confident about the overlap of those curves, only the general shape of the curves.
The o-rings were the largest in this assortment from an Amazon o-ring kit pictured here; link https://amzn.to/3s3xQuT
Here are photos of the tweeter with o-ring seal, front and back:
@profiguy Very interesting you should mention the TW034, because that's where my quest originally started. I built this system https://www.diyaudio.com/community/threads/open-baffle-bass-reflex-hybrid.393837/ with Audax TW034X0 34mm classic soft domes matched to Troels Graveson waveguides. (http://www.troelsgravesen.dk). They have high efficiency like you say.
The TW034 tweeters sound very good. They are laid back, they have a soft, very non-fatiguing character which is great for some people. But to my ears they're a little midrangey and not edgy enough. So I started this thread because I wanted 1) to use the less expensive, easier to obtain Visaton waveguides, and 2) have a more detailed, more aggressive tweeter that could still keep up with a high efficiency woofer.
Your suggestion of the Audax gold dome is quite interesting, I'm sure that would be a very efficient and detailed sounding tweeter.
@Hiperia I have better measurements today. These are with the SB Acoustics Satori TW29R tweeter mounted with a Visaton WG148R waveguide. I measured it on a sheet of cardboard, which greatly reduces the diffraction effects in the mid-low parts of the tweeter's range.
0 and 45 degrees for o-ring:
0, ~20, 45 and 60 degrees for modeling clay between horn and tweeter:
@perrymarshall I’m interested in your findings as I was looking at building your flanagansters and finding a less expensive option for the tweeter/waveguide.
@bloozestringer The TW29R as above, or any other popular matches for the WG148R waveguide will work well, because the higher sensitivity I'm looking for here isn't even necessary because the Flanagangsters are biamped.
Have you looked at the large dia Wavecore tweeters, the TWO30WA11or12 almost fit your wants except for maybe the ultra high spl and no need for the WG as they already have one
As noted above, the ScanSpeak R2904/7000 will do what you need in the WG148. However, there is a nicer waveguide that fits the Scan perfectly, and is acoustically the same as the WG148.
See here for details:
(1) https://www.diyaudio.com/community/threads/open-source-monkey-box.327594/post-5852940
(1) https://www.diyaudio.com/community/...scan-speak-waveguide-circular-version.340608/
These are clearly very good tweeters and can work here, but the Wavecor waveguides are optimized for flat on-axis response instead of Constant Directivity. Their off axis response tilts downward faster than I would like, and for this application I need a waveguide that's at least 6" in diameter. The Wavecores are 4.5" in diameter, which means they don't have any directivity at all below 2K. That means the radiation pattern won't match the woofer around 1500-2000Hz.Have you looked at the large dia Wavecore tweeters, the TWO30WA11or12 almost fit your wants except for maybe the ultra high spl and no need for the WG as they already have one
The family of curves just linked by @mbrennwa is what I'm looking for. The comparison between those and the Wavecore is instructive.
@mbrennwaAs noted above, the ScanSpeak R2904/7000 will do what you need in the WG148.
Do you have any high SPL measurements of this tweeter?
Looks like it will achieve 113dB in the top two octaves (5-20KHz), at least according to the datasheet.
In the waveguides suggested, do you know if it can reach 115dB, as per OP requirements?
I have a (mainly academic) curiosity in this tweeter, as my system is limited by the R2604/8330 dome tweeter, as it maxes out at 110dB@1m- dynamics compression effects creeps in:
https://www.diyaudio.com/community/threads/high-dynamic-range-104mm-dome-tweeter.386061/post-7020212
What the one from 2002?
HHH tested at 90dB- a walk in the park for the R2904 (or R2604)
I shall await testing by Perry.
They also tested linearity vs level. That's what you want to look at.HHH tested at 90dB- a walk in the park for the R2904 (or R2604)
- Visaton WG148R Waveguide: Highest SPL tweeter with flat faceplate?
