PASS preferred resistors
Thanks for the link. I will need to study this at leisure!
A quick glance shows that the 2sk117GR I have in my drawer are better than I thought 🙂
Now I just hope they are not fakes haha. Can't remember when or where I got them. I think a Dutch surplus store, probably 10 years ago.
Reactions: Oneminde
I don't think a "standard" DIY'er has the equipment or skills to do resistor noise measurement properly?
https://dcc.ligo.org/public/0002/T0900200/001/current_noise.pdf
I guess the resistor is the most linear component we have. Compared to e.g. a transistor.......
I think for myself to reduce noise the time spent is best done on layout of amplifier in chassis, how wires are routed, power supple etc......
But interesting scientifically topic for those who will and have the skills to measure and compare noise generated by various brands of high quality industrial resistors (if one brand comes out on top I could be tempted to use those).
A resistor can also pickup noise just by its size if someone is tempted to use some very special purpose resistors for audio 🙂
The same with capacitors. Very large film-caps can pickup noise even that it have better specs compared to a smaller ones.
Compact SMD circuits are not that bad i think.......regarding noise....
Page 11 should give you some idea!
  • Screenshot 2023-08-19 at 20-41-07 Current_Noise_Measurements.pdf - current_noise.pdf.png
Perhaps worth it to read the whole paper. I haven't yet, but this one shows that not all are created equal, at higher frequencies.
  • Screenshot 2023-08-19 at 21-13-13 Current_Noise_Measurements.pdf - current_noise.pdf.png
You should seek out Bruce Hofer - designing analog circuits with ultra-low - lots of good material.
The 1206 size SMD is still a relative “sweet spot” in terms of price and availability for precision resistors. And is a good choice for thermal release as any smaller is a compromise.
Reactions: Joseph K
I think it is safe to conclude that:
a. not all resistors are created equally
b. some measure higher noise in the audible range than others
c. although 3rd harmonics seem to dominate, the levels are not the same
So, perhaps my 24 resistor test setup was not so daft after all 😎
I went over there.........but stupid I did not bring any hearing protection........so I went quickly back again. I did not have a ticket either......so......
Those cars are too loud.......I got a picture! ......it is far above the "pain-limit".....
But that is not Johnson noise.......so back to Johnson noise 🙂
