Low-Cost PMC-inspired TL Monitor with DC130A and DC28F
Yes, the WG300 waveguide on my PTT6.5 TL speaker gives enough time delay that I can use a passive Harsch XO for time aligned speaker.
https://www.diyaudio.com/community/...using-ptt6-5-and-rs28f-in-a-waveguide.354778/
cf790e3c-21c3-4918-bb37-81eac893bc89-jpeg.856179
XO schematic:
ptt6-5-rs28f-wg300-new-xo-schematic-jpg.868139
XO curve:
06-ptt6-5-rs28f-harsch-xo-simulation-freq-jpg.845671
Step Response:
10-ptt6-5-rs28f-wg-harsch-xo-impulse-jpg.845675
Reactions: peterasaad
I have not read all this thread, but I thought this data might be helpful for you.
This is the PMC AML1 line. Ignore the decimal places, it is probably only accurate to the centimetre. Width of the line is about 165mm. I have some photos somewhere, let me know if wanted.
Somebody also measured the woofer T/S online. I dunno how reliable the data is but this is what they reported.
PMC AML1 Woofer t/s:
Fs: 62,48 Hz
Re: 4.00 ohm (dc)
Le: 0.182 mH
Le2: 0.890 mH
Qt: 0.43
Qes: 0.50
Qms: 2.93
Mms: 36.25 g
Rms: 4.864265 kg/s
Cms: 0.000179 m/N
Vas: 4.43 l
Sd: 132.73 cm²
BL: 10.666486 Tm
Lp(2,83V/1m): 88.29 dB
Fs: 62,48 Hz
Re: 4.00 ohm (dc)
Le: 0.182 mH
Le2: 0.890 mH
Qt: 0.43
Qes: 0.50
Qms: 2.93
Mms: 36.25 g
Rms: 4.864265 kg/s
Cms: 0.000179 m/N
Vas: 4.43 l
Sd: 132.73 cm²
BL: 10.666486 Tm
NIce,
Please share more details and photos .
Thank you!
:cop:
Please post in English.
Привет от България!
Искам да попитам автора на темата XRK971 има ли промяна в кутията на оригиналния чертеж в началото на темата.
Ще използвам тези високоговорители:
https://www.soundimports.eu/en/sb-a...XnnqPtGAynkTLXgTMR_6IbX7VCvhjOMHZMkaAtXbEALw_ w cB
https://www.soundimports.eu/en/sb-acoustics-sb19st-c000-4.html
Тази рисунка имах предвид.
Hello from Bulgaria!
I want to ask the author of the XRK971 theme if there is a change in the box of the original drawing at the beginning of the topic.
I'll use these speakers:
This drawing I meant.
This is what I get, I had measured at 1m at middle point between woofer and tweeter.
@xrk971 - I have moved my speakers to a different room now, so thought of revisiting the measurement of the TL with RS180-8/DC28F version of mine.
Getting a huge dip around 40hz due to which the low ends are getting cancelled, seems a room issue any suggestions to fix it?
This is the crossover I did it for them now
Measured response in room
Reactions: audiomovil
