Is it possible to cover the whole spectrum, high SPL, low distortion with a 2-way?
The impression that I get is: "We know that THD is meaningless, but it's so easy to do!" Like looking for your keys only where there is light even though that's not where you lost them.
THD is a useful measure for indicating how loud a well designed speaker can play before distortion starts to intrude. 1% and 3% THD curves on an SPL vs frequency plot ought to be a part of the specs for all speakers with claims to high fidelity because it shows how loud they can play cleanly.
Obviously some forms of distortion (e.g. a sequence of clicks) can be audible at minute levels of THD but they won't be present in well designed speakers (and it isn't sensible to quantify this type of distortion with THD).
I've done psychoacoustical tests where the THD level was about 20% and yet the subjects did not deem it objectional or notable.
The relevance of this is what when it comes to setting the level where raising the SPL of a well designed speaker is starting to create noticeable levels of nonlinear distortion? I presume you are not suggesting that we change from using 1% and 3% levels and use 20% instead? Or that determining a clean operating range for a speaker is of no interest?
Really guys, I am not going to rehash all of our results, but you have some very wrong ideas about the audibility of nonlinearity.
The audibility of the nonlinear distortion typically generated by well designed speakers is not difficult to establish by simply turning the volume control up until it is noticeable. Personally I have little interest in the subjective sound of nonlinear distortion only in ensuring it is low enough in level to be of no consequence. THD is a simple and reasonable way to do that for well designed speakers given the complexities of using multi-tones. Not perfect but good enough if the objective is to identify a clean operating region.
THD levels around 20% or even (much) higher may be acceptable/hardly noticeable in the lowest octaves, but I doubt the same applies to the midrange.
Let's avoid the anal focus on 'how many zeros after the decimal point do you have?'. There's another forum for that.
I agree....it is such an easy, simple, and telling test. Most home audio type speakers get strident all too soon, as volume is turned up.... ime.
On my stronger speaker builds, that maintain relatively low distortion measurements at high SPL.....
well, they just sound better and better as I turn the volume up....
Proof about THD audibility one way or the other? No.
Common sense proof that designing for clean measuring SPL matters? I think so.
Indeed, so the goal is greater system efficiency, i.e. current system is > ~99 dB eff./stereo/~14 Hz in room with dual 30 W rated woofers @ low enough distortion to not be noticeable to all but the most keen of hearing (youths/females) IME at rated power = 10log(60) = ~18 + 99 = 117 dB/m/channel peaks/97 dB avg. dialog, so significantly > THX cinema reference's 85/105 dB, ditto the LFE's 95/115 dB due to corner loading (ancient cheap RS meter isn't up to the task, so not sure beyond guessing > 100/120 dB), which is much too loud for most folks in a typical size HIFI/HT app and with the changing demographics of my neighborhood over the decades now much too high for me, though (competition level?) 'boombox' vehicles till bedtime and after Sunday Church services are fine though........ :headbash: :cuss: 🙁 :sigh:
Reactions: Ro808 and camplo
I meant my neighbor's boomboxes and their much louder/obnoxious 'brothers/sister's' that traverse my through street connecting two major highways at all hours of the day/night; i.e. beyond helping them go (more) deaf when asked, I've never been interested in any more (sub) bass than required for a given soundtrack/app, so having driven most of my life in either a roadster/convertible or on a motorcycle I've mostly had the bass rolled off.
The ideal number and placement of low frequency drivers in small listening rooms has been controversial. Most research has assumed listener satisfaction is determined by the sound pressure as a function of frequency and source-listener position. We believe two additional properties of the soundfield, externalization and envelopment, contribute to listener preference.
http://www.davidgriesinger.com/sfaes.pdf
He's biased towards Concert Halls...
It is interesting to consider what levels of THD we would accept from an amplifier compared to a speaker.
As an occasional fan of high SPL , I set about having a sound system with extremely high headroom.
With 700W per Ch. of high current amp. + bass by 15" & 12" per Ch. & 6x 5.5" in my line array >
nothing ever gets overdriven into higher levels of distortion. Also, having 6 drivers from 600Hz to 4Kz
keeps (the very debated) doppler distortion to a very low minimum.
I like having my system this way 🙂
Reactions: GM
Where any of them peer reviewed? Not by AES anyway...
What are you trying to say or ask with this?
Reviewed or not doesn't change the findings of a paper.
It might sometimes change the overal point of view of a bigger group of scientists.
Although that heavily depends on how those peers feel about certain subjects as well.
Or how a certain idea should be implemented (or not).
For discussing it in detail, I would go back to an old topic;
https://www.diyaudio.com/community/threads/the-gedlee-metric-demystified.287291/
@gedlee I only can't find the >50 sample size, only 34 participants (or 37, both numbers are being mentioned, which is kinda confusing)
Again, I don't remember specific details of each paper and we did numerous multiple subject studies so the specific number of subjects on any particular study has been forgotten. The papers always list this number, so just look it up.
Lidia did the analysis of variance for each study and we did not publish anything unless the results were statistically significant. In fact one of the most interesting studies that we did was not published for this reason, even though I found the results to be quite interesting.
Reactions: camplo and GM
These numbers are directly from the papers, including conflicting numbers, that's why I was asking.
