PEECEEBEE V5 GB
The board is damaged and I have to make a new one. The problem was that was not increasing bias... I changed everything but nothing happened. The offset reset normally and the only difference in the measurements with the other board was that r31 r31 had 1.7k...... in the good only 0.2k. I also can't measure mV in the resistances you give in the instructions. I will need a new board immediately...
Correct me if I am wrong. R31 measured 1.7K while its marking bands read 220R (Red Red Black Black)? If yes it would be very odd. Generally metal film resistors do not get made that much outside their marked value. The R31/32 will not get in the way of changing the offset but with such a high value it should cause VAS bias related issues which I think happened in your case.
I do have some boards left. I will PM you shortly.
Finally got the amp singing.
@shaan .. it’s beautiful. Thank you 🙏
Will wait for the break in now.
Som
Reactions: 5 users
Beautiful looking V5, Som!
Can you post a pic of the inside?
Linear or SMPS?
Thanks @Vunce . I’ll post the internal pics soon. Been busy with work but l did make some time to give it a serious listen and the amp is simply fantastic. From the day 1 to day 2 the amp is settling down quite nicely and I think another couple of more hours and should be able to hear the best out of these. Getting more musical 🎵
Waiting for the next GB from Ostripper for spooky and hell raiser 😀
Reactions: 1 user
Bias at 300mA and!!!
OMG
Sound from another planet....
Shaan this time exceeded all expectations
Keen to know what was the difference like. I have currently biased it to 150ma like Shaan suggested in his build guide. Will bump it up over the weekend. I have big heat sinks too so heat should not be problem.
Reactions: 1 user
