New Bliesma 142mm mid dome
This is an unusual driver, but it has some serious lower midrange / upper bass capability.
Sd = 180 cm^2, that is more surface area than a 7" woofer, and almost as much as an 8" woofer.
Fs = 65 Hz, when most typical dome midranges are 300 Hz +
Qts = 0.3, Vas = 25 liter... more like a midwoofer than a dome.
The sensitivity of 95 dB/2.83V makes this driver pretty unique. I know of no cone driver with this high sensitivity AND an Fs below 70 Hz.
Not many at this cone size. Only i know is supravox 165 gmf
This mid is pretty out there In design was kinda shocked at its size unpacking it. Next to It is bliesma,kartesian 6.5 lom pa ,purifi 8 for scale.
Reactions: 4 users
It look interesting.
Thing is, I don’t see the point in their shift from 8 to 6-Ohm nominal voice coils, other than it makes the driver appear more sensitive - they tested it at 2.83V, not 1W. The irregularity in the response between 1-2kHz leaves me questioning what is taking place in that region. I hope the distortion is better than it was with the M74 midrange. At this price, I would expect a full measurement set, not just the impedance and response as seen in the data sheet.
Oh wow! That open ring magnet assembly is incredible. Reminds me of a woofer that used to be sold on Madisound probably 10+ years ago. Was very low profile, had a honeycomb diaphragm and a completely open magnet structure just like that. I think it was about 10" diameter, but I can't find it anywhere online after searching for about a half hour and have no recolection of the brand name.
Joined 2005
Prescient Audio Thindriver
https://audioxpress.com/article/prescient-audio-td-12-a-new-12-thindriver
disappeared into thin air (no pun intended)
I wonder what the founder is doing now…
Reactions: 2 users
Joined 2005
These perimeter driven drivers are not new. Yes Accuton has a few models in the CELL range with it, but not all.
eg.
C168-6-990-CELL
C90-6-724-CELL
Like all neo drivers, they are lighter than ferrite motors. But apart from being novel, I'd like to see some data of the purported benefits.
Distortion at 104db at 3 ft distortion does rise a bit below 250hz 1 percent at 96db so I would say this driver is good between 250 and 2k. My box is not good at all I've already had to go to get weather stripping. Here's 104 94 89 I would say they are okay drivers.
