Has anyone here DIYed a streamer?
Depends on what level you consider "DIY". You can build streamers based on a Raspberry Pi or similar SBC (single-board computer) and class that as DIY. If you want to do "lower level" DIY, you can implement a Raspberry Pi compute module (which is the route some commercial producers take) on a custom board. You can of course also try to build the whole thing from scratch with your own processor, but that's probably a bit over the top.
Last but not least, some smaller processors/uCs are now powerful enough to process high-res audio and in that case you can build something that looks a bit like the compute-module based solution but with much lower complexity.
Reactions: bamavette
Obtaining an Rpi4b board is the biggest challenge. Otherwise, with an Rpi4B board, a good metal enclosure like the ones from Argon which not only provide good shielding but also move all ports of the Pi to the rear of the enclosure, a good linear power supply and choosing from a host of Operating Systems, you are ready to go with a fantastic sounding music streamer. Attach a storage drive or/and use any streaming service.
pics
The DIYA thread is here .
I used Daphile a while back and it works well. I think an RPi and Moode sounded better You really want he lowest power CPU that has the processing power to accomplish the task. I currently use an RPi 2 with Moode.
I tried umpteen ways to install this and no matter what it hangs on "Waiting for network connection"
It is meant to run headless like Moode, Volumio, etc. You use another device on the network such as a phone, tablet, or computer with a browser to access the IP of the Daphile on your network (assuming it properly connected to your network). See the instructions.. Requirements "Another web browser equipped device to access Daphile". Find the IP of Daphile on your network and enter the IP in the browser address bar of your phone or tablet. You don't actually control it from the computer that it is running on, although, if I remember correctly, there is a way to do that.
