MA12070 no sound
My power supply is a 24V Lifepo battery. My amp doesnt have dip switches i connect IN0A and IN0B as the positive and negative outputs of my bluetooth receiver. I’ve tried other receivers even direct 3,5mm jack and nothing happens
If it's like this it's the other way around, but it should work regardless. Without differential inputs it's not going to output much power.
