PCM1794 -- simplest I/V possible needed
In the
Testing the pcm1794 thread,
https://www.diyaudio.com/community/threads/testing-the-pcm1794.221743/
smms73 described an I/V test rig comprised of:
this test was made by connecting the pin IoutL+ to a classical ampop I/V converter (opa2134) with a resistor of 50 , 100, and 150 ohms in series.
the pin IoutL- was connected to ground.
https://www.diyaudio.com/community/attachments/opamp-iv-png.306974/
What I need is fast solution to getting acceptable sound from the output of a PCM1794. Something one just plugs RCAs into and get okay sound (or at least a hint of what is possible with the PCM1794)
Will the test rig described above suffice?
Or does one need more stuff added?
I would just follow the data sheet and figure 24, pretty simple.
I/V Section: The current of the PCM1794 on each of the output pins (IOUTL+, IOUTL–, IOUTR+, IOUTR–)
is 7.8 mA p-p at 0 dB (full scale).
The voltage output level of the I/V converter (Vi) is given by following equation:
Vi = 7.8 mA p–p × Rf (where Rf = feedback resistance of I/V converter)
An NE5534 operational amplifier is recommended for the I/V circuit to obtain the specified performance.
Dynamic performance such as the gain bandwidth,:
It really is pretty simple, don't let it scare you. Can you work with the surface mount PCM-1794?
Do you just want to breadboard this for a quick try out, or keep it for a longer time?
Remember you do need the output filter (in the second op amp stage) to get rid of the digital "noise".
Here are cheap, completely built-up boards you can easily try out, no idea how good they are. There are others, too.
https://www.aliexpress.us/item/3256804416281126.html
https://www.aliexpress.us/item/3256804416615342.html
The photo shows as far as I got 12 years ago.
I saw Fig. 24, and thought ... "way too much work".
Maybe "Hawkeye". So, no "Voyager" and the La Grada Famila is still un-completed to date.
How about the smms73 circuit in the top post? If the simple smms73 circuit works, even a little, I may even (ultimately) tube it.
his is not "Simple & cheap" 😏
grunf's PDF?
But neither is what you responded with:
http://www.pavouk.org/hw/modulardac/en_pcm1794a.html
Draw up your:
Simplest and cheap - will be 4 resistors for I/V (2 for each stereo channel) and dual OP (one OP per channel) like NJM358 as diff. amplifier.
It's "simple and cheap" to Google web pages -- low hanging fruit. However: If one puts forth the effort, the Cosmos allows for ... (not a fruit -- it's healthier)
If you are able to read schematics, You can see there exactly what i said - I/V on resistors (R17, R18), and diff.amp on one OP.
But there are 22 parts total here. What you post is not much different to others' high-part-count suggestions. If it takes that many IV parts for the 179x to work okay , then I may abandon the project for opt for he $12 dual Chinese kit,
BTW: Who is pavouk.org ?
Use four 120 ohm resistors for I/V and four 1uf capacitors in series to output. No filters is no problem for just get proof of concept.
No clue here ... someone please sketch this out. ... smms73 stated something similar in the pcm 1794 thread ... and it turns out there was an op-amp that popped up in a later photo.
I can attach to the small proto in my earlier photo.
If I get some clue as to what to expect, I may even be persuaded to along this ...
https://6moons.com/audioreviews/yamamoto7/dac.html
Yes, but simple and cheap.
BTW, using dual OP - not 22, just 19: 14 resistors, 4 capacitors and one chip.
LM358 or 2904 (which is the same), costs 15-20 cents.
But i
f you have a sensitive amplifier, you my use only resistor-based I/V with one of the DAC's differential output.
You will need only one resistor for I/V and one DC-block capacitor. Nice to have also RC-filter at the outputs,so
totally - 2 resistors+2 capacitors.
This maybe even better than TDA1540 or 1543, or similar garbage.
Who is pavouk.org ?
I don't know, I was too lazy to draw a schematic, so I just found a similar one on the Internet
