Iron Pre Essentials Kits For The DIYA Store - Register Your Interest
I don't suppose it needs to stay below the radar.
I'm working with people to see what we can do to get a few chassis from Gianluca out before they potentially go into the store.
Wasn't my idea... that credit goes to Kevin. I'm just trying to see if I can help out. May or may not happen.
We should probably talk (you’ve got my number) I’ve already ordered my chassis from Gianluca…if others would like to order one, sooner is probably better then later.
Reactions: Russellc
^ Thanks, Kevin! Much appreciated. I'm on the road.
All others - If you'd like a chassis like Kevin ordered for his balanced version - Feel free to get in touch with Gianluca directly. Feel free to organize a small group buy amongst yourselves or order directly if you're in a hurry. Gianluca is always a pleasure to work with.
Note, last I checked, these chassis were still prototypes. That status may have changed. I have not checked on the SE chassis. I'd strongly recommend that those interested check out all the dimensions and relevant information before committing. Gianluca should be able to provide that info, and they'll have the latest files. If not, ask here.
I'll step away from the action, but the group can feel free to ask more questions here.
Not Particularly difficult for YOU…but bear in mind this will be going into the store and will be completed by builders with a variety of skill levels so it should be idiot proof. Or should I say @KevinHeem proof. I’m just trying to address as many question now rather than have a hundred down the road.
For what it's worth, I didn't find BA3 pre that difficult, and Iron pre prototype even less difficult. Iron pre has power supply, pre circuit including the transformers and the selector parts all right on the board. BA3 requires separate board for power supply as well as the relay selector. Hope this helps with difficulty level.
Russellc
Reactions: A Jedi
Russellc
Agreed, since it’s all integrated into one board that makes it relatively easy. It’s just not like building an ACA Mini…that’s all I’m saying.
