LU1014D Small Amplifier 6 Watt with low distortion
The recommended version is now https://www.diyaudio.com/community/...-watt-with-low-distortion.397378/post-7306466
Power Supply in this post https://www.diyaudio.com/community/...-watt-with-low-distortion.397378/post-7311145
This amplifier uses two LU1014D JFET.
Max power output is like 6 Watt into 8 Ohm.
The distortion is low and mainly 2nd harmonic. As can be seen in image.
What you need:
4 x J113 JFET
1 x ZVP3310A MOSFET
2 x LU1014D Power JFET
And a good power supply 2x12VDC. Preferably regulated
@EUVL Your LU1014 curves look surprisingly similar. My experience with these parts is very different:
https://github.com/mbrennwa/curvetracedata/tree/main/LD1014
https://www.diyaudio.com/community/...-by-vgs-and-curve-tracing.381338/post-6902977
But let's go back to the nice little amp presented by the OP! @lineup did you measure the distortion spectrum, or is this a model calculation?
The distortion i SPICE is 0.00028% at 8 Ohm 1 Watt.
The Fourier spectrum then is like the image in my first post.
At 6 Watt the dist is like 0.020%
Of course I know that real life figures are not at all the same.
SPICE is a limited thing. Not for real.
Just gives you a hint what circuit may work.
I never actually build my circuits.
I leave that to others.
I am more of an idea maker. To inspire.
Nelson Pass is also an idea maker.
The difference is he actually make real amplifiers. And tests.
Sure you have Nelson.
My choice of transistors is depending on what goes on in this forum, Pass Labs.
My idea is that people will have them from Pass designs.
And so they can easily build my designs.
Sometimes it works. Sometimes my designs are forgotten - with no real use.
I do not like amplifiers with exotic devices. Such as ordinary people can not get them.
I think you know very well what I mean.
Your designs are exemplary in this respect.
