UGS-muse preamp GB
No, you are fine with one encoder on the right and the buttons.
The 2nd one is nice if for some reason you can not mechanically implement the buttons. A hole for a 2nd encoder is easier than putting numerous buttons on the faceplate. Also the 2nd encoder is nice for optical symmetry, if this is what you like.
Yes, the firmware supports currently
  • main encoder (on the right) with buttons (original design)
  • dual encoders only (functionality added later)
  • dual encoders with buttons (was left as some liked it and could potentially use the buttons as direct inputs select, etc)
One of the files was posted here in the past and has the description for the push buttons and encoders also, the other file was edited and has the description only for the encoders.
The other attachments are my blowtorch clone for which I recently finished the pcbs.
If someone want to try it can be found online shared by Milan, search for Uskok.
  • Menu - UGS _ Muse edition - control encoders only.txt
  • Menu - UGS _ Muse edition - control.txt
Reactions: Pars
Yes, they have the 450s. No 550s there.
Are these the best parts to use (i.e., is this what Pass used)? There are lower noise parts than these, but haven't looked at all the specs. Also, does the eline package fit the heatsinks with the SJ109/SK389 better than a reg. TO92?
Not stupid at all!
It’s a line stage without global feedback, it was designed many years ago by John Curl.
You can find more info searching for Moxtone Uskok.
I dream about this baby for many years… but at that time I didn’t have the knowledge to put it together, not that now I have a lot but I did a bit of progress lately.
To use it with the ugs preamp you just remove your actual gain and buffer modules and plug in this pcb.
Reactions: starcat and Ine
