Time warp! Back to the future 2008 postDon't want to give you work. But do you have a list somewhere on all the types etc you have tested. I have a local supplier that has some RCA pairs. And some other brands he does not list. I'd like to ask if he has certain brands.
I.e. current limiting resistors to help with turn on surge for rectifier long lifeWith the CT tap I mean this:
On 100dB speakers anything small is audible. Easier is apply output FFT to watch harmonic noise spikes and experiment. At least monitor on a scope trying to achieve cleanest output line on max vertical sensitivity while without signal. Or worse case use a good DMM set on AC mV. Try alternative wiring schemes to read less mV on idle. Since your implementation is personal regarding PSUs and housekeeping decisions can't be sure, but I would first compare heater supply lift vs grounding approach.
Thank you Salas.Time warp! Back to the future 2008 post
10dB line gain on 100dB speakers ought to bring out some of that too. But it differs between tubes. The 6Π6C has bit more than some others in my experience but not that much.My son hears some faint hiss as well. Luckily I have old ears.
What's the purpose of your attached schematic used for heaters?Will check thanks. I've been stupid really...I connect + and - of the heater to the "thingy" which is meant for ac. I suppose I should connect only minus. After which I'll try connecting straight to ground as well.
TIA
100dBs are a lot, also depending the power amp....I have 100dB speakers. There is a little hum and buzz. My son hears some faint hiss as well. Luckily I have old ears.
Haven't investigated yet. Any pointers?
To elevate the heaters above cathode potential to prevent potential noise leaking to the cathode. MJ added this circuit to lower psu noise I think. But it is debatable if it make a difference at all. I just used it because it was on the board. But still will try as Salas suggested that I might just ground the DC instead of lifting.What's the purpose of your attached schematic used for heaters?
My system is plain old typical inefficient, ProAc speakers. I hear a slight trace of noise, what I'm guessing is thermionic noise from the tubes, I really have to press my ear right up against the drivers to hear it. Not a problem for me. But would there be a benefit to placing the volume pot after the output caps? Our would that mess up the feedback?
- Tubes / Valves
- 6V6 line preamp
