LM1875
Hello, is this LM1875 PCB design good?
Any advices?
(First time posting)
Jim, take a look at this link which composes a simple PCB that fits many of the older chip amps. The fake board issue is discussed.
The LM1875 and the newer TDA units are available on Mouser. There is a family of these amps, pick one that is best fit for your requirements. Chip amps are fussy about layout so maybe not the best for NewBee if that is what you are.
Hello, took 2x LM1875T/LF02 for a BTL configuration as seen in the PCB design.
I "baked" the PCB today and works pretty well, i dont know how to calculate the noise tho. (barely audible on tweeter)
The LM1875 has less bass than the A2030V IC's. (The A2030V is 40 or more years old and i did not found any datasheet for it so i used 30v and 40v on the LM1875 IC's).
Yes the heatsink is grounded and yes both IC's are isolated from the heatsink.
Conclusion :
IDK someone with more knowledge and a little time to spare has to check the board design. For me works more than fine.
I'd be careful with those long leads to the ICs.
The reason your thread saw little action is likely that your board layouts are hard to read. The LM1875 will work well if you build the circuit shown in the data sheet. It's available from TI: www.ti.com Make sure to follow the recommendations for decoupling and layout in the applications section of the data sheet.
Tom
Jim, in order to share your design you need to present a schematic, a layout, and explanation of your design goal. Unfortunately, the official layouts in the TI docs are just blurry copies of PDF images .. no good. But there are plenty of examples on the WWW.
None of them are using grid boards which are unsuitable for chip amps, IMO. If you want to be a pioneer, you can try soldering vias together to match the tracks shown in a reliable layout.
1875, 2030,and 2050 are interchangeable, except for the difference in supply voltage, so you will get thousands of PCB designs on the web.
And in all those years, the kinks would have been ironed out.
And the populated, ready to use boards will cost you only about $ 1.25 here in India, with 'equivalent' 2030...they work well enough at about 18-24 V.
No ties to seller, just a net image to show the item.
I would get a few, test and see, and change out components till satisfied.
Extra in case one gets blown up, shipping is cheaper for a slightly larger shipment, not much difference in shipping cost for one or three boards.
Hello and thanks for reply.
My bad, i will remake it and add more info. (thanks for pointing out errors)
I know there are plenty designs but i want to make one of my own.
With this design i can fit 4x LM1875 in BTL mode for 2 channels.
Edited:
Forgot to mention the 4 IC's on the same PCB.
Hello.
Here 1 board is 1.42 euro not a big difference, but aren't SMD components bad for the sound quality?
"1875, 2030,and 2050 are interchangeable, except for the difference in supply voltage" yes i know.
"but aren't SMD components bad for the sound quality?"
Given the same properties of parts and their inherent parasitics and given the proper part for the proper job has been picked, I would always choose an smd part over a through hole part with regards to "sound quality". For example in your case of working with a TO220 package it is possible to put SMD decoupling capacitors and the feedback R directly onto the pins to minimize parasitics.
Reactions: Jim Jason
I think you are right, i will give it a shot.
Thanks for the info.
