Those Magnificent Television Tubes
Fair enough, but it really doesn't matter... In the following circuit, the 6V6 doesn't GAF if that TVS is there or not... Without that SA12CA, the MOSFET quickly turns into a wire (especially without RY1!). A lot of MOSFETs have a protection diode built in anyway...
RY1 is drawn incorrectly. It shorts the MOSFET G-S for 10 seconds, then opens. There's no connection to ground.
Here's a sample circuit using an n-channel enhancement mode differential front end. The diodes connected to the input are already low capacitance in nature, but still more so, as they are reverse biased by about 15V. The capacitor and zener backing the diodes help absorb ESD energy. So, it's definitely more parts than a pair of zeners/TVS, but a lower and more controlled capacitance directly connected to the input. If you're feeling a mite paranoid, you can use larger diodes at the input instead of the 1N4148. The larger diodes will still have reduced capacitance due to the reverse bias.
I don't understand why my post illustrating an alternate clamp circuit for a mosfet front end was deleted, as it was in response to a poster that was using back-to back zener clamps for a mosfet diff stage feeding a tube output. Yes, it was an SS amp but it was illustrating an alternate clamp circuit for a mosfet differential front end.
unsolicited advise, please start a thread about this as this invited off topic discussion...
Sorry you feel that way... I thought it was relevant to the thread. We were talking about MOSFETs and how some people think strapping a TVS diode across gate and source destroys the circuit or something...
If you don't, report it and see if the administration will remove it.
I've been trying to understand output stage loadlines lately. The loadlines posted by kodabmx on page 88 of this thread go way above the max power curve. Is this acceptable (and typical?) because it's push-pull class AB, and it's the average power that matters? If I had class A push pull, would It be recommended to stay below the max power curve?
Yes and yes.
Best regards!
Reactions: jgf
Same here, and I posted my questions above too.
As I understand it the difference between these sweep tubes and normal pentodes is that the g2 winding is not shielded by the g1 winding, so the g2 is as much a plate as the anode, but with much reduced current handling capability. To tame those tubes it is not just the current flow in the g2 that is to be considered, but also the interaction between the g2 and the whole tube.
I built a clone of the Tubelab SPP with PL84 tubes, and even being within the published characteristics I had red-plating issues. I also discovered that maximum specs were not the same in different manufacturers' data sheets so an effective design needs to assume the lowest common denominator. The TV tubes were developed for roles in standard TV chassis and were tested with that in mind. They were one trick ponies.
