6V6 line preamp
1st pic left DSD128 & 2nd pic right DSD64 both 1kHz 0dBfs before the LPF.
I don't understad why both don't measures 1kHz also why different gain? I didn't set well the Brymen?
TIA
For a simple test I would use a cellphone or laptop audio output, and simply look up a 1khz test tone file or youtube video, then measure the voltage at the input and output. This will avoid the DAC and ensure the circuit is the thing being tested without extra troubleshooting.
I have an old 2014 era iPad I use with a test tone app specifically for this just in case theres an issue. That way if it fails I don't lose anything important due to circuit errors or high DC on inputs, etc.
Reactions: merlin el mago
