Wasn't that a Homer Simpson thing? He looks at something and it blows? Uiuiui!
(I feel similar)
I'm not sure if I observed this correctly: Had the impression the fuse didn't blow right away, it was more like it was gone (the led-bar, that is) after power-on again...
Haven't yet examinated the situation...
What is the procedure to examinate the state of jfets and the likes?
BJTs simplest check is with DMM in diode mode. You look for one diode drop. Say its NPN. You put red probe on base and you read about 0.5V when black probe is touching each other pin. For PNP you put the black probe on the transistor's base.
Just shows if junctions are broken or not. Crucial. No need to remove it from board.
Just measured J1, J2, Q2, Q4 both sides (the other pair to complete and confirm it)
They all look similar:
J1 left:
source-drain: 94R
source-gate: 1.1R
J1 right:
source-drain: 70R
source-gate: 1R
J2 left:
source-drain: 90R
source-gate: 1R
J2 right:
source-drain: 94R
source-gate: 1R
Q2 left:
source-drain: 0.26V
source-gate: 0.64V
Q2 right:
source-drain: 0.112V
source-gate: 0.54V
Q4 left:
source-drain: 0.26V
source-gate: 0.66V
Q4 right:
source-drain: 0.27V
source-gate: 0.67V
I'm not quite sure what it means besides that no part is really off of each other.
Beginning to hope there's just another silly wiring-glitch or soething?
What do you conclude of this, or where should I put my fingers on next?
Thank you so much!
J1 left:
source-drain: 94R
source-gate: 1.1R
J1 right:
source-drain: 70R
source-gate: 1R
J2 left:
source-drain: 90R
source-gate: 1R
J2 right:
source-drain: 94R
source-gate: 1R
Q2 left:
source-drain: 0.26V
source-gate: 0.64V
Q2 right:
source-gate: 0.54V
Q4 left:
source-drain: 0.26V
source-gate: 0.66V
Q4 right:
source-drain: 0.27V
source-gate: 0.67V
Thank you so much!
Went one tiny step further:
Confirmed transformers, they're good and connected the right way.
Swapped transformer (connected one channel only)
DCSTB
channel 1 is +-17.4VDC,
channel 2 is still outputting weird numbers, +24VCD -42VDC (bright LED-bar on the +side)
DCSTB
Transistors (Q) have collector base emitter not drain gate source.
In any case "q2 right" gives different diode check readings. Is it located in a problematic section?
Remove the DCSTB and replace that q2 for starters. Test again the problematic channels without outputs connected to DCG3 or anything else except inputs to a transformer.
Only scenario I can think of for such readings is 24V raw DC passing on one side and about -17V expected output DC referring to it somewhere. 24+17=41.DCSTB
Yes I did. (Didn't even try to do it wrong way. What would happen? (Sorry I'm such a greenhorn and curious!)Did you follow the NPN PNP probe polarity guidelines?
I'll order parts (1 part, that is. Must invent something to fill the basket.) This will take a few days, which I will use to try and see what's with the VC (using the good channel only. 😉
What would happen is inconclusive readings regarding the internal diodes of the transistors conducting or not.
Meantime pull the suspect out to probe it again in isolation. Do you have a cheap component tester for seeing more?
No, I'm afraid not. But I got this capable multimeter, does that count?
https://www.soselectronic.com/products/voltcraft/vc276-324405
If you have not yet placed the parts order, and don't want to place it for just one part, consider getting some stock of all the transistors in this design and maybe another bridge as well. Best way to insure you won't need them!
I am struggling to understand the mechanism by which the DC servo in the DCG3 can affect the sound of the amplifier. All the authors I have read say that servos can affect the sound of an amp, but I'm just not seeing it. As a load on the output, the 1meg resistor is insignificant. And the output of the servo, a very slow moving DC signal of a few tenths of millivolts that brings the offset back to zero: how can that be heard? I would love an explaination of why a properly designed DC servo can affect the sound of an amplifier.
I may reluctantly do so…some stock of all the transistors
Keeping a stock of parts is a bit a part of the rabbit-hole, isn’t it? And, as I have built several other things and more often than not ordered some spares, but still haven’t managed to develop sort of a muscle-memory on electronics (I still don’t have that comfy feeling of understanding), it’s basically a big, growing bunch of loose parts…
OTOH: „I can see clearly now the partisoutofstock…“ (
Another way to see it is as a dynamic high pass filter on the feedback node.I am struggling to understand the mechanism by which the DC servo in the DCG3 can affect the sound of the amplifier. All the authors I have read say that servos can affect the sound of an amp, but I'm just not seeing it. As a load on the output, the 1meg resistor is insignificant. And the output of the servo, a very slow moving DC signal of a few tenths of millivolts that brings the offset back to zero: how can that be heard? I would love an explaination of why a properly designed DC servo can affect the sound of an amplifier.
- Analog Line Level
- Salas DCG3 preamp (line & headphone)
