What's going on with LM3886 availability?
I have 2 left willing to send to anyone who'll pay the postage. One is slightly dirty because it was not inside the protective plastic thingy...but just lying around in some parts box. Other than that they are both NOS.
My understanding is that TI (and others) took away the stock notification because it was being used by the grey-market 'dealers' to grab inventory. As mentioned by blu, I find it best to check TI (or Digi-Key or Mouser, etc.) regularly for the things I need and sometime I find the small DIY quantities showing up as in-stock. In spite of what you hear in the media about demand going down, it doesn't seem to me to be reflected in availability for small customers like us. There are still a lot of things I need (including common resistors and capacitors) showing out-of-stock and very long lead times.
LM3886T/NOPB is the metal-back version with lead-free solder on the pins.
LM3886TF/NOPB is the insulated version with lead-free solder on the pins.
LM3886TF is the insulated version with leaded solder on the pins.
The chip inside is the same. The difference is in the packaging and pin finish.
Tom
Reactions: 6L6
