'Off timbre'? But the hump is not in the freq response, right?
Jan
yea the timbre is off.
it’s not natural.
i don’t know how to put it.
all ESS DACs have this weird top end. Around 1khz and up.
throws everything off.
it gives instruments no breadth
The benchmark DAC3 had the best low end detail of any DAC I’ve heard though.
but it’s upper mids and above were off.
timbre was just not good
sorry
sorry
Had a Benchmark DAC-3 too. Soundstage was forward and towards the middle. It used SRC4392 to upsample everything to 24/192 (actually a little higher than 192 -- maybe it 211kHz?). After the upsampling was a custom filter in FPGA, then into the dac chip with ASRC still enabled, but DPLL_Bandwidth set to a low number. Harmonic distortion compensation was hand calibrated for each unit. Topping D90 was preferred over DAC-3, even though there were some audible problems with the Topping at vocal frequencies and higher.
Had a Benchmark DAC-3 too. Soundstage was forward and towards the middle. It used SRC4392 to upsample everything to 24/192. After the upsampling was a custom filter in FPGA, then into the dac chip with ASRC still enabled, but DPLL_Bandwidth set to a low number. Harmonic distortion compensation was hand calibrated for each unit.
all I know and if you remember it had amazing low end detail.
but besides that yes it was forward and flat
and the timbre was off from the midrange up.
not as much as the Topping D90SE I tried.
that one was horrible.
the benchmark DAC3 I at least had some enjoyment with. Would put it in and out of my system.
amazingly the topping D30pro which uses the Cirrus flagship chip was insanely better than the D90SE.
And the thread started out so promising ...
Jan
why did it disappoint you?
what didn’t you like?
legit question
Do you have vinyl?
no but I am thinking of getting it again someday
CS43198=43131 uses some cheating to deceive the AES17 DR test, as told me ESS design-team member. That's why the THD+N -115db of this DAC is rather typical for the DR <120db(A), i.e. way worse than claimed 130db(A). The DAC switches its gain dynamically, the same way as ES9281 does if "Dynamic Range Enhancement" option is On.
As the thread starter I have to agree with Jan. The problem is that many dac related threads end up as arguments over subjective opinions about sound. And this thread is not even about dacs but adc.why did it disappoint you?
legit question
Its gone way, way OT. I agree with Jan, it started out promising.why did it disappoint you?
It started with facts and figures then degenerated into personal preferences and unsubstantiated claims.why did it disappoint you?
legit question
Ohh well.
Jan
How much in the way of facts and figures on the ESS hump can there be? Its been hashed over, measured, and discussed for years. What else do you want to know?
Back to the topic, the hump is related to the DAC's HF noise which overloads I/V opamps. Well-filtered DACs outputs produce no or at least so tiny hump that APx555b can't see that. That's it.
Unfortunately with low output impedance switched resistor dacs, filtering the dac outputs before the I/V op amp to prevent overload tends to increase distortion due to dac internal CMOS resistor nonlinearity. Sometimes a little bit of filtering there can be the lesser evil though.
- Design & Build
- Equipment & Tools
- Return of the ESS hump
