Important Update:
Hello everyone.
This is the very last batch of PeeCeeBee V4H Rev2 PCBs that are still available to order. After this batch is exhausted no more V4H boards will be printed. A clearance discount of USD5 is added, so the boards are available at USD15 instead of 20.
The main reason for this decision is that sourcing genuine Lateral MOSFETs have become a problem for me. So members who still have access to the MOSFETs may want to consider buying the boards. These will come with the SMD gate-source diodes pre-installed as usual.
Happy Winter!
Hello everyone.
Happy Winter!
@shaan , @CitizenKane
Hi fellas,
Given the 100mA bias recommendation for each lateral MOSFET in this design, do you recommend the ‘RED‘ or ‘ORANGE’ colour band matched sets of Exicon’s ECX “S” series of lateral MOSFETS, as seen here? :
https://www.profusionplc.com/pdf/selected-mosfets.pdf
I realize it’s not necessary and that it is expensive (~ USD$8.50/ea) for some folks. I’ll probably go with whatever colour bands they have in stock since one can easily bias at 100-150mA/MOSFET in this design as long as sufficient dissipation from the heatsink is available.
Kind regards,
Anand.
Hi fellas,
Kind regards,
Anand.
Hi Shaan, I am from Bangalore and would like to get 2 Pairs (4 Boards) could please let me know how can i go about procuring these ?Important Update:
Hello everyone.
Happy Winter!
Update:
PeeCeeBee V5 layout has been done and a pair of prototypes has been ordered. Expecting them by 30th Jan.
There are more transistors per board (some bjts are used in diode mode so no discrete diodes), slightly more gain than V4H. Mounting holes for power transistors in V5 are compatible with V4H. Only power transistors sit underboard (on main heatsink), everything else sits on top.
Stay tuned!
Stay tuned!
Thanks for update 👍Update:
Stay tuned!
Awesome ! ExcitedUpdate:
Stay tuned!
- Group Buys
- PeeCeeBee V4H GB
