Scryer ... or how F8 met Mighty SissySIT
Results from measuring resistors in-circuit (power off) below.
Deviations from the schematic:
  • R107 measured 5K (10K in schm)
    • R207 5K (working channel)
  • R108 measured 5K (10K)
    • R208 5K
  • R111 measured 30R (51R)
    • R211 25R
  • R112 measured 25R (33R)
    • R212 23R
  • P101 measured 60R to 0.8R (200R)
I’m assuming the resistor deviations are from interaction with the trim pots?
I’m working on identifying all the little bjts…
All resistors after 114 conform to the schematic.
Little bjts are difficult to identify! See attached.
one pic all "1-B"
second pic all "3-B"
so, my OCD still functional
try checking all resistors in situ, primarily comparing to same measurement on proper channel pcb
be sure to have probes same oriented on both channels
even if in some cases you can't get valid measurements ( resistor being in circuit), comparison with proper channel can give us some idea
Reactions: von Ah
Understood. I’ll check all resistors from the good channel and compare.
To confirm, do you mean measuring resistors with power off? I hope so. It’s tight in there and getting the resistance measurements with the board out was challenging enough. 😀
Correct, the SIT appears to have been the problem.
I luckily got 10 from a dubious source right when the original thread about the K2087C started here. They were obviously pulls from older equipment.
I didn’t spend a lot, and ended up with two pair that have worked for me. Two other lucky forum members got a pair of K2087Cs from me. :santa2:
