Here is a very nice implementation of the large heat sinks by diyAudio member Monk55:
Very Nice DIY Chassis/Heat sink
I am nearly done pulling together what I want for this build. I'm going to do a dual mono power supply with a single Antek AN-10450 transformer in one chassis. The 5U/500mm chassis will hopefully be big enough to allow passive cooling but if not I'll stick a couple of fans outside or under it. I believe I have all the parts in my cart on Mouser or already ordered from DigiKey.
The last piece is actually sourcing the PCB's. Much gratitude to Ben for providing the design and the Gerbers. I'm sure ordering the boards isn't that complicated but I would like to piggy back onto somebody else's order since I have never done that before and would prefer not to have to learn how to do it now. So if you are ordering the PCB's for the amp and power supply boards I would be happy to pay for a significant amount of the cost. My sense is there isn't much difference in price for one set vs multiple sets of boards but maybe I'm wrong. Please contact me if you are interested. I am in the US.
Heat sinks arrived...I notice they are drilled and tapped at top & Bottom. Anyone know offhand what size bolt is required ? Looks like M4...maybee.
DiyAudio store / Modushop 300x210x40
Three holes at top and bottom are different (larger) than the UMS holes for transistor and stand offs. I have M3s at hand and can confirm these holes are larger. I don't have M4 or M5 so...I can't check.I can guess and shotgun it....but figured someone would know.All the UMS heatsink seems to be tapped with M3, see pics.
DiyAudio store / Modushop 300x210x40Where is your heatsink coming from?
Not a big deal....I'll figure it out....thought it would be an easy ask....no need to clutter up the chat.
thanks for the responses though.
Ben.. Did you use any type of control circuit on your fans ? There are many out there in Amazon land but , as always seeking shortcuts.
No fancy control circuit. I built a simple LM317 regulated supply with a trimmer pot to adjust the voltage, all on a piece of perf board. The raw DC is provided by a winding on the Antek transformer and a bridge rectifier. The PS board can be seen on the bottom of the chassis.
The fans are on with the amplifier, and they run at a reduced voltage.
Another great suggestion. I bought one of those NF-P12 fans just to see how it might work and it came today. It is unbelievably quiet. It is so quiet that I can barely hear it with my ear right next to the fan. Assuming it doesn't start squeaking with time there is no sonic reason to be afraid of using one in a build that needs active cooling. Kudos.I use Noctua NF-P12 Redux fans and they are very quiet, and even quieter when run at reduced voltage:
Very Quiet Noctua Fan
My fans have run for three winters of use so far, and this is fourth winter of use. So far they are still quiet. Since they run at low rpm (mine run at reduced voltage so less than 900 rpm), they should last a long time.
On another note, I still have the amps running at 2.5A and enjoying the sound. The distortion is a bit higher at maximum power but that is not an issue for me as the amps probably coast along at less than 1W output most if not all of the time in my system. The lower Iq probably would suit most people too. It is definitely an option if heat management is an issue.
Here is an interesting fan control circuit the ubiquitous Mark Johnson shared a few years ago.Ben.. Did you use any type of control circuit on your fans ? There are many out there in Amazon land but , as always seeking shortcuts.
https://www.diyaudio.com/community/...-temperature-controlled-analog-no-pwm.336346/
Or failing that anyone in Europe?Anybody in the UK planning on getting the some boards made?
Wow.... I don't know what Mark does for a living but I bet they don't pay him enough.Here is an interesting fan control circuit the ubiquitous Mark Johnson shared a few years ago.
- Single Ended Tokin SIT THF-51S Common Drain Mu Follower Amplifier, 45W?
