OK - hope my Virtulabox can support me. Is there an Updater application? Instruction for update?
Thanks!!
OK - I found them. My virtual PC runs NT4 🙂 - will that work?
Also with the Tweak app?
That CT7601 driver - where do I get this?
https://e1dashz.wixsite.com/index/cosmos-adcThanks!!
I'm probably on a too old platform as I get "Not a valid win 32bit application" when I try that Asio exe app.
Yes I did - you installed a driver. When I try to access a page I found with it, both my browsers on Mac wouldn't let me access the page for download.
Can you provide a link to get to CT7601 - it was a part of the video.
Ah, Ok, change the PID for 6012 pls. ADC has 6012, DAC 6013. And pls use a short USB cable with the USB port placed on the motherboard, not an extended port for a stable USB connection. Do not shake the cable during the reflashing process!OK - this is how far I get. USB ADC device captured by the VM... bot no contact with the Cosmos...
so, perhaps a newer Windows is needed.Unfortunately 6012 didn't fly either...
When you say "driver" is that the Comtrue USB ISP ?
In my installation of the CT7601, it comes almost to the end where it ask you to connect the USB to the "device" (Cosmos) and hit OK - when I do this and hit OK, I get a error message saying that the installer could not reach the device. When I do "Cancel" on that stage, it goes to finish and states that it was a successful installation of the driver...
Is this CT7602 needed or not?
Windows Comtrue driver https://drive.google.com/file/d/11LDzaULXWbtP1fyH6j7sp2S2SOF5ve3x/view?usp=sharing
If you can't finish Comtru driver installation, try to install their sys files by alternative way.
No, my son and coder Tyoma escaped from russia to Armenia last March(it is about putin's war), and can't work for me anymore.Is there any new tweak app as latest from 01-sep-2021 🙁
- Vendor's Bazaar
- Cosmos APU a notch+LNA $70 to outperform APx555b for $30,000
