DIY NEAT IOTA ALPHA project. Anybody know what tweeter to use?
Hi, Im a pretty new to DIY speakers. I have just done a couple of kits before.
Now I want to make a "copy" of the Neat Iota Alpha speakers, I like the look of them and I read a lot of good reviews for such a small speaker.
I have been digging around on the net and found some info. I have the dimensions and the name of the woofer and mid drivers.
But Im struggling with the tweeters.
They use Peerless SDS-P830656 woofers and Peerless HDS-P830870 mid drivers.
The tweeter they use are listed as 50mm EMIT Planar Magnetic, but I cant find them on the internet.
These are very cheap drivers and I find it a bit strange that the price of the speakers from Neat are over 2000 $ here in Norway!
So, do anybody know where I can buy the tweeters they use, or can anybody give me some good advice when it comes to pairing the Peerless drivers with a matching (
ribbon) tweeter?
The Neat speakers are 2.5 way speakers and I will add some pixs here.
I will prob need some help if possible with the X-over, but I did read that they are crossed over at 4k and 80 hz
Hope somebody can help me out here.
B
Welcome to the forum! I shall give your thread a bump.
I suspect the EMIT may be discontinued.
Monacor do a range of ribbon tweeters: https://www.monacor.com/products/components/speaker-technology/hi-fi-tweeters-/
This one can cross over >2.5 kHz (@12dB/octave), so satisfies your 4 kHz crossover requirement:
https://willys-hifi.com/collections...bt-1000-ribbon-tweeter?variant=43518010753279
This one is a rather interesting looking product and a good opportunity for a cloning experiment. I am not so sure should the tweeter be left sideways, but I guess it can't be helped if one is to keep its appeal, and the lower woofer should definitely be an sds 6.5".
If I can add to what Ugg10 has previously indicated:
It's a simple enough parallel 2.5 way crossover with a large value inductor in series with the woofer and a smaller value inductor in series with the midrange.
The HF section consists of a series capacitor, parallel inductor 2nd order electrical circuit. A two resistor L pad follows for tweeter attenuation.
The difficulty lies in determining the values of these components and that's where someone with crossover design software might offer help.
from the review-
https://www.stereophile.com/content/neat-acoustics-iota-alpha-loudspeaker
"the Alpha's top section is sealed, thus changing the character, especially in the bass. So we have a sealed two-way speaker with restricted low-frequency output augmented by a low-bass section. It differs from an Iota with a conventional subwoofer in having been voiced and tuned as a complete entity."
If you can't find the planer tweeter. * Not an exact clone.
You could build the cabinet with the divided top section with the Pure Vida or other (post#9). Bass cabinet with 830656 & a low pass crossover.
Rockford Fosgate Box Calculator
https://rockfordfosgate.com/support/box-wizard/
830870 see sealed box graphs- ? litre
https://ampslab-spk.com/2018/05/20/peerless-830870/
830656-
https://ampslab-spk.com/2020/04/30/peerless-830656/
https://www.parts-express.com/80-Hz-Low-Pass-8-Ohm-Crossover-266-442?quantity=1
https://www.parts-express.com/100-Hz-Low-Pass-8-Ohm-Crossover-266-446?quantity=1
Blue Quark- example-used with a low pass crossover
https://techtalk.parts-express.com/...-blue-quarks-with-a-not-quite-voxel-subwoofer
Quark
https://techtalk.parts-express.com/...ery/65800-the-quarks-m-o-s-d-computer-speaker
thanks a lot guys, a bunch of good information here 🙂 Im going to order the drivers now and I hope I can start the build just after x-mas.
Im into these "designer" speakers, and want to build a few different ones. The Iotas I like for their small size but still apparently good sound.
The others are more vintage speakers. I really like when the speakers can be placed on the floor next to a long sleek media furniture, but not not the high tower speakers. As close to the height of the furniture as possible.
I really like these M&K audio speakers , but they are very hard to find any info about. Also it looks like a 2 way with a 8 or 10" woofer, and its tricky to find those for a 2 way system.
I also LOVE the design of the Braun L2 speakers (from 1958!), and I can find some info on them but they are much harder to build, at least the tubing stands.
