SB Acoustics SB10PGC21-4 (3" Full-Range) / normal version and magnet added version.
I am very interested in the effect of adding magnets to a speaker. A speaker I have been playing with recently is the Monacor sp205/8
This has very small magnet (79g) and a ridiculously high qts (2.7)
Would adding a magnet alter this appreciably?
As it is it can only be used in open baffle, or open back speakers (eg k&t cheap trick 269)
I can't measure the Qts so I don't know how much it changes, but SB10PGC21-4 and BG20 have a clear effect.
Some drivers may or may not benefit from the additional magnets, so it is hard to tell without trying.
Does is show in measurement?
Very much so...
Added magnet results: No magnet-qts-1.029, qes-1.132, zmax-37.1ohms
2 magnets-qts-.9183, qes-1, zmax-42.3ohms
3 magnets-qts-.8634, qes-.9352, zmax-45ohms
4 magnets-qts-.8128, qes-.876, zmax-47.9ohms
Magnets were 32mm X 2mm from Amazon, tested on my Dayton WT3. No listening impressions yet.
Larry
Reactions: nandappe
Thank you for the measurement when you added the magnet.
I can confirm the difference by hearing, but it changes quite a bit by measurement as well.
By the way, I have tried from one to three 30φx2mm magnets, but two of them were well-balanced in my auditory sense.
Reactions: larryldspkr
Had a chance to listen to my Tabaq's with SB10's and added magnets (2). I know these speakers well, been listening to them for a year and a half. The improvement was not subtle, I was pleasantly surprised! Dynamic contrast was better, bass was tighter, overall smoothness seemed better, just a better presentation overall. I would recommend this easy mod to anyone using this driver!
Larry
SB10 added magnets and Mod Podge treated dust cap in a 4.4 liter bookshelf. Sounding very nice!
Nice work.
The grain of the wood is beautiful.
any of it took out the distortion peak at 4kHz, by any chance? 🙂
There's no peak at 4 kHz in either the manufacturer's published or measured values.
Reactions: LeifB60
