Looking for SS Phono Preamp
I've made about couple of dozen needledrops from LPs. Typically there are 3-4 loud enough pops per LP that go beyond 0dB of the ADC. That is about 1-2V. Therefore I conclude events that need more than 20dB headroom are too rare to spoil the music enjoinment assuming the preamp has such headroom.
In my opinion, it is more to spoil the musical enjoinment if such gigantic pops are correctly reproduced.
Maybe, but not necessarily. If signal clipping cause some sort of instability of the preamp, produced artefacts might be more objectionable than the pop itself. This question needs some experimenting and research.
Further, spectral content of unclipped pop may be mostly in the ultrasonic region, hence inaudible. But again, this takes more analysis
I am all for good overload margins, but if a record hit +20dB regularly, I would discard it. 😉
Ed
+14 dB is probably the norm. However, I have a classical recording (Stravinsky’s ‘Firebird Suite’) that has a huge dynamic range. The recording clips at one point.
The reason for the >20dB O/L margin is to cater for a signal chain with gains/outputs on the high side.
Reactions: chip_mk
Although I ran most of the sims at 10khz, the behavior at 1khz is very similar as you can see in the last 2 printscreens.You can see a clear difference between a "marshall-esque" type of soft clipping and bare hardclipping caused by 20db higher input signals:
Well...ask an electric guitar player about the types of distortions...And hard clipping does happen a lot with dust on records .Some op amps come back faster from saturation...others not that fast, but all suffer of hard clipping with the right signal on the input.
Just realized one trz in the previous simulations was in the air, but the op amp was doing all the job anyway...ignore the diamond buffer...it's there for a different circuit.I'm working right now on such a circuit so I'm tuned to the subject...
Then I wish you good luck with explaining the reason for this datasheet:
It is very simple to resolve the dispute: you need to digitize the LP, made with a level of about -20 dB or lower, so that the entire dynamic range of the phono stage fits into the ADC scale. There you will immediately see if there was clipping of the amplifier. I can't give an example of clipping.
I wash once when I buy a used record. I replace the paper sleeve with one that does not generate dust. Any remaining pops are permanent.
Not so. I had one new LP with a terribly loud pop in just one place, that persisted for many cleanings and playings.
Then one day it was completely gone. The foreign particle had finally worked loose.
