3D6 headphone amplifier
Sorry for my crude hand drawing - I am posting from my cell phone.
The input is 10-step autotransformer attenuator, followed by transformer phase splitter. The 3D6s are independently biased by Li-ion cells whose voltage can be finely adjusted from 3.2 to 4.0 V. 3D6 filaments (connected parallel) are powered by a NiMH cell, which is automatically recharged when the amplifier is off (charger and it's connection are not shown). Filament battery switch is ganged with power switch. The choke between primary CT and B+ serves as CCS, ensuring strict Class A differential operation. The choke is sectionally wound (to reduce winding capacitance) on 2-bobbin nanocrystalline C-core; it is a custom job. Solid state CCS can be used instead, but choke sounds better. Depending on the source signal level, the output power is 50-100 mW. The amplifier is intended for the Sennheiser HD650 phones.
Very interesting! No cap in the signal path this way. How about using AC filament instead?
3D6 has interesting filament - two closely spaced parallel strands. When the filament is powered with 3 VAC, its halves are in opposite phase, so there is very little modulation of tube's Gm. So, yes, this particular tube can be used with AC filament, especially in PP. I powered filaments from center-tapped 3 VAC winding, center tap grounded, and there was no hum audible on headphones.
Reactions: rongon
That’s good to know. Thanks for sharing! What’s Mu of 3D6 in triode operation?
Then plate resistance is close to 4k ohm per tube. I wonder what would be the optimal load? Would it be better to go for higher than 8k ohm for the differential circuit?
Minimum load is about 10 K P-P, but the higher the better. Less distortion with higher output impedance, and for headphone power doesn't matter. My output transformer is 15 K two plates to line.
An alternative to additional voltage amplifying stage is a good quality step-up transformer in place of 1:1 input transformer.
Thanks! What I am thinking is to add a SE DHT pre and use 2-3 times of load in the 3D6 differential amp.
Forgot to ask, do you use 1 transformer 1 winding shared by two 3D6 tubes? Or each tube uses a separate winding? Thanks.
One center-tapped filament winding for both tubes, as of the schematic. The center tap is grounded.
BTW, parallel strand filament is used in several other DH RF power pentodes. 1P24B, 4P1L, 2E24, 4064, 1624. Makes these tubes suitable for AC heating.
Reactions: Fei
What did you buy? I have had some Chinese ceramic ones and they can be a tight fit but were OK in the end. I bought a load of NOS wafer style ones to make a tube adaptor on an Octal base, and they have been excellent (though no one likes them here). Otherwise the best source is auction sites and NOS.
Are the russian and american loctals the same spacing? I'm a little unclear on the specifications.
I'm using 2P29L's and using the chinese ceramic ones. They were super duper tight, but I removed the metal spring thingy in the socket, and works perfectly now.
I was also thinking of trying out these 3D6's myself, in a line stage
