Help please, powering up a pair of huge diy amps .
Was the person you bought them from the person who powered them last 10 years ago? If they were working last time i'd be much more inclined to just plug them in. I would probably short the input and connect a dummy load to all outputs the first time, unless i had some disposable speakers. Connect one channel at a time and assuming your house breaker doesn't trip wait and observe (and smell). Like previous posters have written do this in an area you're not very worried about just in case something pops. Main issues assuming it doesn't smoke or smell much is you don't know if the chassis is live (for me personally i don't differentiate between DIY and commercial stuff, i trust everything equally little) and you have no idea of the sensitivity of the amp. So you don't want to electrocute yourself and you don't want to blow your (disposable) speakers.
One thing i always do is wait 30 minutes after powering them down before powering them back up again, just in case there is some NTC in-rush limited involved. Measure if you have any voltage across the dummy load, should be negligible. Never connect or disconnect anything while it's powered up and don't touch any part of the chassis. It's good to use a power extender with a switch on it in case something does happen and you want to cut power fast, you typically don't want to grab the chassis to yank the power cord out.
Those trannies could be output trannies and in that case you definitely do NOT want to send a signal into the amp with nothing connected, that could spell bad news for said trannies.
Well I’ve stripped down one of them .
Is there anything within of any value? Or is it scrap ?
