I'm initially going with Audio Labs DQ40S, I also have a pair of Mark Audio CHN-110. But they really need a FHXL. I'm also getting a pair of MA PHD70s or HD70s. Not sure which of the two is be
They look very similar to the Audio Lab albeit for a white cone. Alas try as I might I just couldn't get the same presence, detail or highs with the Pluvia 7.2 HD. So a 2 way design beckons ffor them down the road for them. Imho the Audio Labs are outstanding in the FH3 and certainly satisfy my Jazz taste with intricate cymbal work etc.I've used this one.
Inferior to any Markaudio. It works fine on FHmk3. I don't know if it's worth at 20€/each.
GHXAMP 4"
Excellent feedback, this driver is a new candidate.
Did you get at least a 100 hrs on the P7s?
dave
dave
Negative. Just over 40 hours so far, at low volume. Subtle change to the bass and mid, but zilch on the top end Dave. I followed the stuffing plan to the letter. Swapping to the Audio Labs tells me it's spot on.Excellent feedback, this driver is a new candidate.
dave
Stuffing tends to be a bit different for each room & each driver so your stuffing is right for the Audio Labs, but tells little for the P7. But stuffing will have little effect on the top.
I always put a couple 100 hrs before putting them in a box — as you start to give them a bit more welly they will continue to change.
dave
dave
That seems to be the case. Because athe P7 was the first driver to be installed. When I heard a damped top end I popped them on a spare amp, and in free air started the running in process with white, brown and pink noise as I always do.Stuffing tends to be a bit different for each room & each driver so your stuffing is right for the Audio Labs, but tells little for the P7. But stuffing will have little effect on the top.
dave
Popped the Dq40s in to listen. to them and the disparity became clear. I will try them again after the 100 hour mark and go from there. On the upside, after waiting to build a pair for a couple of years it was very worthwhile as they sound fantastic! On that note thanks for the help over that time period. Likewise with Scott.
Unlikely as they are running at a very low volume, but yes I will run music instead.Use real music not artificial noise!
I do hope you have not trained them badly with the noise
dave
Another 24 hours on the P7HDs and they have burst into life? There is now a brilliance to the high frequencies. Yea!
Absolutely!!! Sounds crazy, but they are totally different speakers. They seem to have gained a deeper bass as well as more openness.:^)
A big one!
dave
More of a big Grin Dave 😁 But yes I was getting fraught, so all's well that ends well.Typical experience. So good to “see” the joy on your face (and some surprise?)
dave
Just ordered a pair of ESS Heil tweeters during their big sale. They are the perfect size to sit on top of the Mk3's. I plan to try my own version of Ed Schilling's Great Horned Heils.
I was so close to using a super tweeter with the P7HDs. Fortunately. as burning in continues the HF is getting very good and would have been too much in my case. Sounds like an interesting project.Just ordered a pair of ESS Heil tweeters during their big sale. They are the perfect size to sit on top of the Mk3's. I plan to try my own version of Ed Schilling's Great Horned Heils.
What driver in the FH3?Just ordered a pair of ESS Heil tweeters during their big sale. They are the perfect size to sit on top of the Mk3's. I plan to try my own version of Ed Schilling's Great Horned Heils.
Ed wasn’t smart enuff to tweak the FE126, so cut them low to cut out the part where they have issues.
We had a Heil (original). They are quite good, versitile. Prefered them 2k up w less aggressive XO.
Unless biamped you need a lot of padding. Impedance is very flat but XO complicated by monopole to dipole transition.
Have fun!
dave
I have three I can try ( MA, CHB, and Fostex ). I've heard Ed's which were bi-amped with a Boozehound active and was impressed.
Sorry if this has been covered, but I can't seem to find a "search thread" feature.
Has anyone modeled the FH Mk3 for the Daytron RS100-8, or is it a lost cause due to the relatively high Qts?
I'm considering trying to build a set of these, but I can't find Alpairs. Plus, I've always been a bit of a tinkerer...
EDIT: Found the thread search option! No results. 🙂
Most 4ish inch drivers work. Really low Qt makes bass a struggle, really high maybe… this one has been asked and tried and deemed good (not me).
The use of damping in the horn allows for an ability to be good with a wide range of T/S.
Madisound has Pluvia 7HD for $100/pr, they have some A7p for $50 pr (they need a long break-in and there are a few tricks), A7ms for $150 pr.
P7HD probably best bang-for-the-buck. It is the evolution of the Alpair 7.3.
dave
dave
- Full Range
- Frugel-Horn Mk3
