It is a 2-channel card, the two HP negative outputs are at 0 V, like class ab amps and some irs 2092.
I think it is in btl mode because the chip has 4 ch.
No perceptible noise...The only noise heard is that of my test source.
I will say more when I have connected it to my dac and good hp.
Could I ask were you acquired this board? I have the 1.2 version and haven't managed to get it working. Also did you have a red led pop up at any time or just green all the time? Seems I have a faulty unit.It is a 2-channel card, the two HP negative outputs are at 0 V, like class ab amps and some irs 2092.
I received version 1.3, the LED is always green in operation.
It turns red for a short time when the board is turned off.
For your board, this is not normal, it does not say anything good.
What voltage are you powering it at?
Try to contact Michael Xiao in PM?
Powering at 30v so should be fine not sure how to pm people on this website?! I'm new to this forum!I received version 1.3, the LED is always green in operation.
It's frustrating as I seem to have bought from a shitty Aliexpress seller. They don't want to help me. In fact they stated I didn't handle the product properly and that's why it doesn't work. Very Infuriating as I've built up several amp boards with no issues. Could you send me the link were you purchased your board from? Thanks!
You have tried with a symmetrical switching power I presume?
1 rail +, 0V, 1 rail - ?
The link to my board is on the 1st page of the topic.
Do not linger too long with the sellers of alli, unfortunately they often do not know their product...
If you paid with paypal, you have the right to buyer protection...
Perhaps this is my issue. Not sure what a symmetrical PSU is? I have tried with meanwell drp 240-24, meanwell lrs 100-24 as well as the below pictured supply.You have tried with a symmetrical switching power I presume?
If you paid with paypal, you have the right to buyer protection...![]()
Ok, it's a single rail power supply v+ and 0v, that can't be suitable.
The board may not be dead for all that...
If you have two power supplies like this, you can connect them in series by connecting the + of one to the - of the other, this will act as a 0V terminal.
The remaining + will be the + terminal, the - remaining the - terminal, the voltage will be 60 volts between the + of one power supply and the - of the other.
English is not my default language, sorry if it's not clear....
Or simpler...Find the right power supply!
Come on, fingers crossed! 🤞
This amplifier is an SE output amplifier. The power supply requires two power supplies, + and -.Is it singel channel in differential?
How about the noise?
The MA5332MS amplifier chip can be used with BTL connection, but it will be monaural 1cH.
However, I think that this amplifier board does not support BTL connection.
It's a bit confusing that ali board.This amplifier is an SE output amplifier. The power supply requires two power supplies, + and -.
"The MA5332MS is available with differential or single-ended input and multiple output configuration options - single-ended (2x SE), bridge-tied load (BTL) and single-ended in parallel (PSE), and supports dual or single supply. "
Yes, the board amp is single ended is unmodifiable in btl according to the designer.
Looking at the data sheet of the MA5332MS chip, it is possible to have the specifications you say.It's a bit confusing that ali board.
However, this amplifier board has a limited specification.
The power supply requires a +- dual power supply and the output is limited to 2ch SE output.
Please tell me.Yes, the board amp is single ended is unmodifiable in btl according to the designer.
Does this MA5332MS amplifier board make pop noise when the power is turned on/off?
Light click on ignition, almost nothing on extinction.
The little click when switching on is perhaps caused by the power supply...
I must try with another, I received a connex electronic power supply, but not tried yet ...😕
The subject board here is single ended, and requires a balanced power supply.
the hp outputs are referenced to ground 0v.
Only a board in btl mode could work with a single rail power supply...but the output will be mono...
Il existe une carte d'évaluation infineon btl, mais elle est trop chère à mon avis... :confus:
https://fr.farnell.com/infineon/refma5332btlspstobo1/carte-d-eval-ampli-audio-classe/dp/3931204
I have now also ordered the MA5332 board from Aliexpress. With what voltage can the MA5332 board be operated?
I still have a power supply with +/- 40 volts here, is that too much?
You should be fine...but pay attention to the operating voltage of the op amp capacitors and regulators.
The MA5332MS chip supports 100 volts max, but the rest of the components must be sized for it !
@mamocel
Have you had a look at this amp yet? It seems like a new listing and comes with a built-in PSU.
MA5332MS Class D Digital Power Amplifier Board/stereo Dual Channel/high Power Module 2x200w - AliExpress
- Class D
- MA5332
