There are great sounding and not super expensive 2-way designs. Why go for 3-way, then?
because 10" still pump much less air then a 15". ditto 12. Im debating whther for my next project im going with a 18" woofer or dual 15"
my system is a 3 way, first order xo, hi efficiency. using a 15" was pretty much forced as I needed the 95db efficiency of the Bass to match the mid. theres not much 10 or 12" that are 95db efficient
A 12" sub with twice the excursion will equal a 15". But if you're considering 18" or 2 15"s, you must not have any typical home set up, rather some huge room?
Physics dictates there is always some driver overhang and the bigger you get, the more you can run into that.
I run at about 85-88 db, but hey bigger amps 🙂
Maybe look at Blast King...18" subs!
https://blastkingusa.com/
I'm looking at some large and expensive studio monitors, and I wonder, why are they so large? Why do they have two of everything, and at least three ways? My immediate thought is that it is for power handling - they simply need to be LOUD. Is there any sound quality benefit to these designs at 80 dB volume? Or could we remove the duplicate drivers (still leaving the three bands, of course), and have the exact sound quality at lower levels? I'm thinking that more drivers = shorter excursion = better linearity, but at the same time these MTM designs have known drawbacks as well.
Yeah a 12" will keep up at twice the excursion, and for that you pay the price in power compression, distortion, and non linearity in the drivers, so it's not a free tradeoff either.
Klippel testing etc shows very well the non linearity in drivers at high excursion, and very few are made to a quality that is impressive past a few mm of excursion.
There is always compromises to be made, and Hoffmans Iron law still applies.
In your case your mainly looking to trade loss in efficiency for smaller enclosures, that's one compromise and i guess the most common in todays 'hifi as size, design and WAF is often more a deciding factor then the rest, so it is the senseful way to go for a large manufacturer looking to sell in high quantities.
Wether it's the right or best approach, is a discussion that will never die so each to his own.
Reactions: youknowyou
yes, 15" woofers in large cabinets make their presence known at 80db, even at 60db. thats the advantage of HE, it sounds good at low spl.
"more drivers = shorter excursion = better linearity,"
but the point to use a 15" is to match a mid. the goal is simplicity
What known drawbacks are you refering to?
Main studio monitors are sized to play clean at loud levels often in fairly large rooms. Midfield monitors is the jargon for speakers sized to play clean at standard levels in rooms typically found in the home. The Neumann KH 420 is a well designed example with plenty of supporting information on the website. There are similar speakers from other manufacturers like Genelec.
Reactions: Alexium
At around $1000(ish) well designed examples of commercial mass produced 3 ways start to outperform 2 ways in terms of technical performance at standard levels in an acoustically reasonable room. A touch less for DIY but not by much because DIY isn't particularly cost effective at the budget end. A 2 way using a 5.25" midwoofer is not able to play low frequencies cleanly at standard levels in a room or midrange frequencies for that matter should it attempt to reproduce any low frequencies. The laws of physics are the problem rather than anything to do with the quality of drivers. In order for an expensive 2 way or small 3 way to be relevant requires the objective to be something other than maximising high fidelity in a room at standard levels. For example, sitting close at a desk, listening quietly rather than at standard levels, wanting low output at low frequencies because of room boom, small size, etc... Nothing wrong with constraints (apart from not mentioning them!).
I couldn't disagree more regarding a budget-end DIY 2-way using a 5.25" midwoofer. Mine, a Jeff Bagby designed Piccolo, uses just such a midwoofer and sounds excellent in a rather small room listening in the near field.
And this is far from being true:
"In order for an expensive 2 way or small 3 way to be relevant requires the objective to be something other than maximising high fidelity in a room at standard levels."
I would put my $450 DIY kit up against any commercially manufactured 2-way costing 5 to 10 times as much. I say that having auditioned many speaker products in retail stores before buying and building the kit.
Sorry Andy. I've agreed with you on some other posts, but not on this one.
I agree, as said in an earlier post, I use a 5 1/2" Dynavox midwoofer with a 3" VC (unusually large size in a midwoof) and it reproduces bass nice and clean down to its rated 100 Hz, and at SPLs into the 90s (although I don't usually listen much beyond 85). With a 3" coil, it can handle up to 60W continuous, 100W peak. I listen in about a 400 sq. ft. room, about 10 feet away.
Suppose you had just two instrumentalists come to your house to play a piece for just flute and cello. Say the cello guy is sitting down and the flute player standing, so the emanation of sound from the two instruments was some vertical distance apart (this happens in an orchestra too just more instruments). This is the way you would be actually hearing the piece. Even though its perhaps recorded with one mic, then you play it back through you speakers, with the xover most of the cello comes out the woofer and most of the flute out of the tweeter.
Do you hear anything coming out of your speakers, or does it come from where the stereo arrangement puts them. Further, is that enhanced by the sound of the recorded spaciousness to aid location...
In any case I'd rather make the point that even if an artificial stereo soundstage is not completely accurate, the recording can still be perfectly enjoyable.
Personally I do not expect my system to sound like a live performance, which be be very good or mediocre depending on which seats you can afford to buy, but I want as good an approximation of such a performance if it was recorded as such. With so many of my recordings being studio albums all I need to hear is what the recording engineers and the musicians have decided is what they want me to hear as accurately as my budget allows.
Reactions: Drummer2005
My current "reference" diy (read: kludge) resolves deep bass drumroll and complex triangle "solo" over full orchestral climax (Karajan coupling of Dvorak bass drum concerto nee New World Symphony with Smetana triangle concerto nee Moldau). Yesterday I compared my favorite whizzer-less drum-paper 5.5" one-way 10L TLonken against Quad ERA-1 flat-panel headphones, and the powerful fullrange didn't resolve bass drum & triangle as cleanly as either the 'phones or my reference Ultrae (two-way sealed 6.5" resin-coated-carbon-fiber-cone-plast'ed subwoofer-flat-to-7.5khz and active electrostatic supertweeter, then augmented by 4x7 vintage alnico widerange). My conclusion: perhaps plast'ed or otherwise-treated one-way could do it; two-way certainly could; but three-way sounded "ultra sultry".
The biggest one is that most designs do not adhere to the D'Appolito's rules regarding the relation between the center to center distance and the crossover point, which has to be much lower than in TM. If not done right, there are comb filtering and lobing issues because the three drivers are no longer a point source.
Having read a few forums threads on this matter, the consensus is that MTM can sound great when done in accordance with the D'Appolito's rules, and not so great when it isn't, which is the case with many MTM designs.
What's that wonder driver?
Even if it is flat to 7.5 kHz on axis, it has to be beaming off-axis, creating a dip in the off-axis response.
Described here https://www.diyaudio.com/community/threads/whizzer-and-intelligibility.185012/post-7154646
I haven't noticed a problem nor measured it, but the plast-rosette helps with dispersion. The electrostatic supertweeter (ESKMO EST-200 not shown) is itself bookshelf-speaker-sized and the entire baffle is waveguide. A supersize-alnico Rola 4x7 (also not shown) used as midrange sits naked on top, forming a bizarre sort of MTM with perfect vertical dispersion to my ears. (Note: top & bottom both go through 0.68mH~940hz LPF.)
Reactions: Alexium
