SB Acoustics SB10PGC21-4 (3" Full-Range) / normal version and magnet added version.
SB10PGC21-4 has a small magnet and weak driving force, so the sharpness of bass sound is not so good.
The addition of a neodymium magnet improves the sharpness of the bass and the sound quality in the all range.
[ Air-Recording ]SB Acoustics SB10PGC21-4 / normal version
[ Air-Recording ]SB Acoustics SB10PGC21-4 / magnet added version
Nice 👍 , but I have to admit I had a lot of difficulty hearing any differences between your two recordings - with and without the magnets.
Maybe my headphones are not good enough, or... maybe the compression Youtube does to the audio makes it impossible to hear what you do sitting in front of the speakers? I will listen some more. 🤔 I don't know if it's worth it, or interesting to you, to try to measure any differences and show the chart(s)?
this magnet is glued or just holding from it's own force? Where did you buy this magnet?
Hi Nandappe,
Question when adding neo magnets does it repel when mounting on center of pole piece ?
I tried this on my Coral Flat 8 with single 10 x 30 mm neo. Strangely which ever side I mount
the neo mag will just be atrracted to the pole piece but when I place the neo to the side of the
Coral where the ferrite mag is exposed I can orientate for push & pull on the neo.
Reactions: gnat_leader
Up to a certain distance, they are repelled; closer than that, they are attracted.
@nandappe you might want to try your experiment again?... because you might be doing this wrong.
A famous speaker builder has said that the magnet should be placed the opposite of what you are doing.
Here is a quote from him about the subject of adding a magnet...
http://www.troelsgravesen.dk/HES.htm#size
An additional 90 magnet was added to increase sensitivity. When you add an extra magnet it has be to pushed away from the speaker's magnet. If the extra magnet is sucked in, it will decrease magnetic flux in the gap. Strangely enough, if it's very easy to get the extra magnet in place, it usually only means a small increase in sensitivity. If you really have take special measures to keep the magnet in place, there's usually an significant increase in sensitity. I keep the extra magnet in place by tape after adding a small amount of silicon glue between the two magnets, and add a clamp overnight.
This is only in reference to a big Ferrite magnet. When you use a neodymium magnet of only 30 mm in diameter which is about the size of the pole piece scenario would be different. This is what I found when mucking around with my Coral flat 8. Regardless I found success, there is a gain in clarity.
Cheers & thanks to Nandappe for sharing
Nice, thanks for that info. Very interesting how the size of the magnet matters.
So you found adding small neodymium magnet(s) to the Coral flat 8 improved the sound?
Can you elaborate on the "gain in clarity"?
