Measured vs Specified power ratings of Pass X600.5
I have a pair of Pass Labs X600.5 monaural amplifiers with the following specs according to this webpage: https://www.passlabs.com/legacy_products/x600-5
600 Watts at 8 Ohms with 1% Distortion
1200 Watts at 4 Ohms with 1% Distortion
A professional engineer made the following measured powerratings:
499,3 Watts at 8 Ohms with 1% Distortion
725,9 Watts at 4 Ohms with 1% Distortion
He even signs for it:
This discrepancy in power output is significant especially at 4 Ohms where almost 500 Watts seems to be disappeared.
As far as I know the tech is a professional working for decades in the field of highendaudio repairs.
I'm in no way implying that there's been any wrong intention by any party concerned, relating to these figures.
It's only one specific pair of X600.5's I'm referring to and I can't generalize on that base.
Maybe you can shed some light on this.
PS I edited the original post so my question is a more open minded query than a suggestion that the specified values were wrong.
I can tell that my 15" woofer is rated 1000W continuous power and 2000W peak.
But that is a kind of white/pink noise after a specific standard.
If I tried to put 1000W at 20 Hz into the woofer it would be destroyed.
So, we need to know how the 600/1200W should be interpreted.
Reactions: andynor
This discrepancy in power output is significant especially at 4 Ohms where almost 500 Watts "disappeared".
My loudspeakers do not starve for power but it seems to be far from a perfect voltage source as is suggested in the product literature with the doubling of power when the load is halved namely 600 to 1200 Watts.
How can that be? Don't say his AC collapses from 230 Volts to 170 Volts when driving the 4 Ohm load. This is a professional working for decades in the field of highendaudio repairs.
If you do not like it, I will take it. You have to pay shipping though.
I vote for a sagging AC line, despite your disclaimer.
You can bank on that 2008 amp meeting its specs, unless the power supply is degraded due to use or age.
I am tempted to say that too. Every review of a pass amplifier I have read has it considerably exceeding spec. Now even if it was low by that much you are only talking 1.7dB into a 4 Ohm load which in normal operation you are not going to spot anyway. And domestically that's an insane amount of power.
Reactions: Mikerodrig27
Is the 600/1200W continuous sinus power (20 - 20 KHz) into a pure ohmic impedance?
Normally such figures follow a specification. It could be ISO, DIN or whatever?
As said I got the specification from the Pass Labs website and I assume it's continuous power from 20 Hz to 20kHz with 1% distortion. The model is called X600.5 and the 600 reflects it's a 600 Watt amplifier at 8 Ohms, like the X1000 is a 1000 Watt amplifier and so forth.
one non-engineer could say - plenty close to enough power
though, who am I to say anything against mucho cojones amps, Pa is rich because of them
Haha, I do not need more power even with my low impedence low efficiency Infinity's. I received these reports yesterday and I was curious why both these amplifiers did not meet their specified ratings. Especially at 4 Ohms the difference is pretty significant. I suspect that the Plitron transformer can't sustain the railvoltage needed to double the output from 8 to 4 Ohms. I also suspect that with the XA160.5 the Class A version of the (bridged) X600.5 with basically the same hardware, will behave much more as a perfect voltage source than the X600.5. I think the same is true for the X100.5 and XA200.5.
If the 600/1200 W ratings is peak power and the measured are "average power" then you probably have to multiply measured power by 2 to get peak power if input signal was a sinus?
If these ratings were peak power it would have been stated in the specifications. I even believe in the USA it's obligatory by FTC Rule 16 CFR Part 432 to specify these powerratings for home entertaining amplifiers and the conditions they were made in: https://www.ecfr.gov/current/title-16/chapter-I/subchapter-D/part-432. So you can't state a power rating and say later when asked: "Yeah we meant peak power of course... "
