Pass SLOB Build Discussion
Looks lovely. Very nice work! PS: A pic of the various tools you are using would be most appreciated 🙂
I put the crossover board in a chassis from the store for the LXmini crossover which appears to be sold out:
https://diyaudiostore.com/collectio...k/products/acn-chassis?variant=12748671385634
It has holes for XLR connectors so I hooked those up to run it as balanced device if need be (which would of course require a second balanced crossover). If there was some interest it might be possible to get more into the store.
This is the 230mm x 230mm chassis without customization, which is available:
https://diyaudiostore.com/collections/galaxy/products/2u-w-aluminum-covers?variant=12174803716
Not at all! I drilled 4 holes to mount the PCB and ran jumper wires to RCA connectors, power jack and XLR connectors bought separately and mounted in the provided holes in the chassis rear panel instead of using the SLOB supplied connectors made to be soldered onto the PCB. That’s the main point here- the soldered on connectors are fast and convenient but their holes in the PCB can be used to connect wires instead.
As you can see there were extra openings in the rear panel for “high” RCA’s I didn’t use and plugged them. There was an extra XLR opening for “high” which I covered with a plate made for the purpose, drilled a hole in it and mounted a power switch just for fun. Although it doesn’t bother me much, I plan to try paint remover to remove the “High” text from the anodized surface. The plugs and XLR cover were in the LXmini parts kit I believe.
I’ll check if any more of these chassis’ are in the store…
Hello Variac,
I did something similar like you with my ACN (post #370 following). Was a little bit of a pain, to get the print away (with solvent and something soft to 'scratch') without damaging the anodization. 😳
Cheers
Dirk
Reactions: Vix and Monk55
