1 order crossover help
Hi guys ,
I'm an imbecile with electronics and hard-wired crossover elements ,this is why I would like to ask for help.
My woofer set up contains two DaytoAudio rs225 wired in parallel to get 4 Ohm`s . For one of the woofers, I would like to apply 1 order crossover limiting woofer to 200 Hz. I'm using active 4way crossover and would like simplify to 3 -way.
I guess, the main question is what type of coil should be used for the best result ?
  • Air core coils
  • Ferrite core coils
  • Copper foil coils
  • Iron core coils
  • Litz wire wax coils
  • Toroidal coils
Each driver is 8 Ohm's ,when wired parallel combined are 4 Ohm`s , what L1 (1 order filter) should be used ,for 8 Ohms driver or for 4 Ohm driver.
Thank you in advance for participating 🙂
https://sound-au.com/lr-passive.htm
L = ( 0.159 × Z ) / fx
Where:
L = inductance of the coil in Henrys
fx = crossover frequency in hertz
Z = actual impedance of the speaker in ohm at the crossover frequency
Ferrite give the lowest losses but may distort if you want extreme volume,
Air core give the lowest distortion but are much more expensive with suitably low resistance
Re:'Each driver is 8 Ohm's' - no, look at the manufactuers data sheet and get the actual impedance value at your chosen crossover frequency
Is this already a fully passive crossover?
If so pix of the XO and a circuit diagram would help.
It's not as easy as simply adding in one coil to one woofer s the components on the other woofer will need to change to match the new single driver impedance
It won't be a 3-Way; it will be a 3.5Way crossover if passive and in my limited experience doing it digitally/ actively is the easiest way and if Bi-Amping/Tri-Amping it is much cheaper to do it at the top end as components are smaller and much cheaper for the mid to tweeter cross. Passive components for bass frequencies that are of sufficient wire size to not add too much resistance are not cheap.
re:'when wired parallel" - use an inductor for the combined total actual impedance
Diagram shows L1 on the bottom leg, to apply only to the bottom bass driver, no?
My simplified, easy-to-remember formulae:
1st-order XO -6dB per octave i.e. halved (driver impedance in ohm)
high-pass-filter=-3dB@(160khz/imp)/uF
low-pass-filter=-3dB@(160hz*imp)/mH
(e.g. imp=8 HPF@20khz/uF LPF@1280/mH, typically set to equal before tweaking by ear
Thank you for participating "Moondog 55", 😌 I'm using fully Digital Crossover (active speaker system). My goal is, one of the woofers to make 50% passive and instead dedicating two crossover channels and two amplifiers to use one channel and one amplifier.
I need low pass filter...so driver is 8 Ohm cut of frequency 200 Hz. So what mH coil I should use ?
Have mentioned , I'm an imbecile with electronics and hard-wired crossover elements ?
If the RS225 share the volume inside, better stuff that volume good. Otherwise the lower crossed woofer will transmit a lot of the out of phase signal from the other. I would also apply a 2nd order topology, just to use the motor braking.
Re: "What value should be for 7 Ohm ?" - use the formula in post #2.
Re: 'where an inductor should be ?" - if wire as your original diagram, L1 is it
Note that, as wchang has pointed out, my response in post #4 is incorrect if your original wiring diagram is used.
What?
The woofers will be in phase with each other. The one woofer will play higher in frequency only, and not be out of phase. This is in essence becoming a X.5-way design.
Being the higher xover for both woofers exists actively, then there is no need to go 2nd order and change their phase relationship.
I use active, 4-way using 3 stereo amplifiers, there is no way going passive on the first woofer makes sense to me.
If you need deeper bass perhaps you need to get a bigger set of woofers or drop the level of the midrange and tweeters a few dB
Thank you, a pipe is 25 liters in volume to share by both divers and this configuration works beautify.... 30 Hz reproduction sound as clean as a spring water..no complaints in there ☺️
