Sure, there's no problem with rotating a TO92 part to suit a non-original pinout if you are aware of it. A repairer or DIY though, may not be so happy for having to identify and solve the problem, checking source datasheets etc. if they make the mistake of assuming that a genuine 2N5551 is really a genuine 2N5551. This could be avoided by distinctive ID marking or sales catalog references and it's the sort of supply problem we don't need.
More space for bigger input Caps, better footprints for BC546, added probe points for Bias adjust.
Gerber files attached.
Yes it does sound good, i'll change all the ceramic caps with better Silver Mica 1% ones btw..Does it sound OK for you now ?
Yes it is, my fault was a bad listening position (very important btw)You mean bass response is ok now?
Did you change or replace anything?
Can you please provide black and white toner transfer working pdf files for home etching pcbsMore space for bigger input Caps, better footprints for BC546, added probe points for Bias adjust.
Final interaction of my complete personal P3A, i made it to fit into an aluminium case (161 x 246 x 60 millimeters internal)
L
Which Software is used for pcb designing
Looks lovely,Final interaction of my complete personal P3A, i made it to fit into an aluminium case (161 x 246 x 60 millimeters internal)
View attachment 1099145View attachment 1099146View attachment 1099147
I use EasyEDA, really easy and usefull software 😉L
Looks lovely,
What do you mean??I think that you will become an expert soon.
I mean that you have done an excellent work and you will be a very good pcb designer in the future.
Beautiful!
Gerbers for share?😉
Sure!
- ESP P3A
