Only la6541 have been disoldered from not finished shiga pcb using hot air. What chip have problem? Byee
LC78601 pin 58, or better on J3 pin2 (middle)
Press Cd door and you should see transition from low 0V to high 5V.
Tibi
Tibi
I have discovered that j3 dont have good connection so i fixed. For now when i power on laser are coming to cd trotle engine and gears are cracking. So i remove laser and powered again. Laser moving engine are going all the time , even when i push pushing switch near motor, no reaction i have measuered and it work good. Engine have no reaction on door switch, when i have pushing him i have 5v on midle j3.
Something is wrongly cabled, maybe reversed ... and you may have used in place of Q4 a pnp instead npn.
Please check cables, soldering etc
Tibi
Tibi
Yours catalog have 1k and it is bc848. I have found that 1kw transitor is bc848b NPN. So when i pushing doors swith i have on midle pin j3 5v. When dont i have 0v. This dont work corectly?
At last. Shiga is alive? Sory for problems.. but motor cable was revers.. dont knoe how it happend.. very thanks for help! Okey lets go further. It is pasible to do do digits on display more darker ? And what about this adp152 mod? In normal situation you writed that is no sound benefits. And youn gives solution to cut trac,add wire. Byee
- Digital Source
- Shigaclone MKII Black - The builders Thread
