Hans, I left the sixth TO3 out and I was able to set around 12V over the 100R resistors. But for some reason none of the 5 base resistor are conducting, no voltage drop. On the posive side the base resistors are conducting.
A small correction, on the positive side there is 3mV drop in base resistors. Negative side there is 1mV drop in the base resistors. 14V drop in the 100R resistors. R20 and R44 has 8mV drop.
I wouldn’t worry too much. Important is that you were able to adjust the the bias current.A small correction, on the positive side there is 3mV drop in base resistors. Negative side there is 1mV drop in the base resistors. 14V drop in the 100R resistors. R20 and R44 has 8mV drop.
But it seems that your readings are a corrupted by oscillations because 8mV on 0.1R is 80mA while 14 V on 100R is 140mA.
So, remove the 100R resistors, set the Bias to its correct value and measure the voltage drop on the base resistors again.
Important is that your heatsinks are electrically connected to the chassis, if not, oscillation will occur.
Hans
I removed 100R resistors and set the voltage drop 27mV on R20. Now I have around 3mV on negative side base resistors and around 7mV on the positive side so at least they are conducting🙂. But why there is so big difference?
And yes I remember very well the oscillations. I have now always connected the heatsinks to the chassis.
This is weird. I’ll come back to it.I removed 100R resistors and set the voltage drop 27mV on R20. Now I have around 3mV on negative side base resistors and around 7mV on the positive side so at least they are conducting🙂. But why there is so big difference?
Hans
With 270mA bias, this means on average 45mA per NPN and 54mA per PNP.
With resp 7mV and 3mV on the base resistors this would mean a Hfe of resp 64 and 180, not impossible but 180 is very high for the PNP.
The other thing that is almost too nice is that all NPN's have 7mV and all PNP's have 3mV on their base resistors.
So before jumping to conclusions, could you specify the following voltages.
1) NPN: All six individual voltage drops on the 10R base resistors plus the corresponding voltage drop on their 0.22R emitter resistors.
2) PNP: All five individual voltage drops on the 10R base resistors plus the corresponding voltage drop on their 0.22R emitter resistors.
3) The absolute voltages on both sides of R44 and R20
4) The absolute voltage on both sides of R50
Hans
Hans
Here are the values. R20 and R44 should have same value on the other end because they are both connected to f. Need to check again that.
Just forgot to mention that there is also one TO3 on the positive side which is not functional as you can see. Actually the values should be vice versa because then the zero volts corresponds each other.
Thx for measuring all these data.
I'm still puzzled by the base resistor voltages that were yesterday resp 3mV and 7mV, and are now more like 4mV and 11mV, so I do suspect that touching these resistors induces some unwanted effects. To be sure you could connect a Scope to the LS output and see what happens while measuring.
It makes sense anyway to look with a scope how the LS output signal looks like.
But the emitter voltages are roughly o.k.
Adding the current from the positive side results in 346mA instead of the 270mA in R44, but this must could have to with tolerance in the 0.22R resistors, but ... ?
Seemingly the PNP's have very much higher Hfe as the NPN's, 159 versus 61, but I'm still skeptical because this 159 is almost unprecedented.
But the question is, suppose it is true, does it matter ?
In some way this asymmetry is not ideal, but will most likely not result in any noticeable effect.
Hans
Hans
I tried to search base resistors voltages from the past but could not find. We were paying attention only emitter resistors values. Might be that this base resistor asymmetry have been there some time...
I will make the scope measurement in the evening.
Hello Hans,
I have set the bias lower 230mA as you described. I also checked the LS output with the scope and did not see any ringing or oscillation. I do not have a signal source present but was able to use my phone and freq sweep to the input of the amp and it seems to work! I can make some images but it requires some work...
And touching with the multimeter to the base or emitter resistors does not change anything in the output.
O.k. that’s reassuring.And touching with the multimeter to the base or emitter resistors does not change anything in the output.
Putting everything together in its final shape and comparing both channels with the same test signals will give you a reliable way to compare both.
When responding the same, you’re done.
Hans
Mark Levinson No.23 is back in action and I can enjoy music again!
Thank you Hans Polak and DiyAudio again, that was second repair. I cannot thank you enough!
My 23.5 right channel trip when input is reached certain level. Any idea to fix it? Bias and offset voltage is normal.
Hello,
I suspect bad output transistor. Maybe you could take one transistor out at a time and see if the problem disappears?
I suspect the elcos in the overload circuit.My 23.5 right channel trip when input is reached certain level. Any idea to fix it? Bias and offset voltage is normal.
The separate PCB containing this part is located a the back of the chassis.
Those elcos with a brown plastic encapsulation are of bad quality and have the tendency to explode after some time.
Hans
- Mark Levinson No23 repair help
