The Adcom 555 that I heard recently at a friend’s house has a low level mains hum. That drives me nuts. I’m picky about that sort of thing. Not sure if that’s intrinsic in the design as it has a simple linear PSU with big caps.
The Akitika LM3886 based amplifier kit is within budget and I think will sound great with this speaker. It also has a regulated PSU so should be very quiet.
You might look into a 100w class D amp from SMSL or Topping.
I'm considering them as well. What is the finish like on the 'leather' , is it a nice quality vinyl? What size room are you using them in. Mine is about 9 x12ftI have a pair of the 50's and WOW, so good! I'm looking at my next order for the 80's(?) for another room. Did you design the LSA floor standers as well?
Are these cabinets the same as thrones found on Aliexpress etc?I designed the Signature 50 speaker for LSA quite a few months back but it’s finally starting to roll off the assembly line and will be shipping soon.
It’s a 6.5in 2-way bass reflex that uses a premium 28mm silk dome tweeter, and I gave details of some of the measurements earlier in the What’s on the Bench Tonight thread.
Predicted response of crossover:
Step response is quasi transient perfect (inverted due to mic response):
Custom crossover uses inverted passive Harsch topology of my design. All high quality parts like pure copper wire inductors, and custom made film caps and non inductive wire wound resistors:
Impedance as function of frequency shows a true 8ohm speaker with lowest dip at 6.5 ohms above 20Hz:
You can listen to the first sound test here:
First review is now in from Tone Audio:
https://www.tonepublications.com/review/the-lsa-signature-50-speakers-2/
Hi, mine were nice, not a high end leather but a nice grained, look great with the grills off - same size room, with them close to wall and one in a corner. The bass is awesome, I listed to music without a lot of bass so I really like the sound as it kinda "eq ed" my sound to exactly what I wanted, much better than expected.
I do recommend a long burn in, I let mine play for a few weeks before really sitting to listen. The treble was the only issue based on my system, music. When A/B'd with others the 50's had a rolled back high but that was less fatiguing and I tend to like detailed highs but this really hit a sweet spot for me. I run them with mono block Schiit Aegirs, Schiit Freya + preamp. CD through Denafrips Ares II dac....I have a ton of speakers ( my weakness) I found them so good that If my only pair I'd be happy, I do have the new 80s which I haven't tried yet but bought on the recommendation that they are a step up, same designer ( thank you) and I also have a LSA Warp one class D amp that I A/B'd at length against the Aegirs mono blocked and surprise it was very difficult to hear a difference. Again the same designer and I'm very happy. Stopped my endless gear quest...If I had a wish it would be for the warp ones to able to Monoblock and a way to disable the led when on as I leave them on all the time. Perfect match for the speakers, most any speaker really.
I could have saved a lot of money if these products existed 20yrs ago....now I have a lot of gear to sell
Thank you for the kind words. Sorry about the LED being too bright. Try a black sharpie on the red one. I’ll see if I can adjust brightness of LED on future batch.Hi, mine were nice, not a high end leather but a nice grained, look great with the grills off - same size room, with them close to wall and one in a corner. The bass is awesome, I listed to music without a lot of bass so I really like the sound as it kinda "eq ed" my sound to exactly what I wanted, much better than expected.
There is a way to monoblock the Warp-1 if you are interested. It involves flipping a DIP switch inside and changing one of the wires leading from buffer to the amp. Then connecting output to specific binding posts. But so you really need to drive 2ohm speaker?
Never heard of thrones? But these cabs were made for LSA.Are these cabinets the same as thrones found on Aliexpress etc?
Hi and thanks! I thought about buying another to mono block for more power if possible, they certainly get loud, I do have some 4 ohm speakers that like power....if possible that would be great, I'd assume the power rating to increase as well(?)Thank you for the kind words. Sorry about the LED being too bright. Try a black sharpie on the red one. I’ll see if I can adjust brightness of LED on future batch.
In mono block parallel bridge tied load (PBTL) mode, it doubles the current capability but not the voltage. So the power only increases if the load impedance drops (2ohms etc). If 8ohms, no change in power. There is a difference from single ended (SE) output vs bridge tied load (BTL) as the power does go up since rails are effectively doubled.
Sorry thrones the ones I saw on Ali and Newbecca looked similar. I assume the sides are real wood..Never heard of thrones? But these cabs were made for LSA.
Is it a vinyl type wood grain or a thin wood veneer. I assume the black surface is a nice grade vinyl? Saw they went up $100 on their website.That does look similar. The cabinet is MDF based and finished with a covering. Tough to have real solid wood for $499.
Only the LSA Signature 50 from Underwood HiFi will have been designed by me with my crossover and driver selections. A speaker from another company may have a similar looking cabinet and finish, but will not not be the same speaker with an inverted Harsch transient perfect passive crossover and optimized components.
No, I did not design the Signature 10. However, I am working on the Signature 100. It will have a ribbon tweeter and a 6.5in XBL licensed aluminum woofer. There is a racetrack shaped passive radiator on the back. The theoretical crossover work is coming along and is starting to take shape.
My lab assistant, is busy inspecting the cabinet and suggests we replace the ribbon with the Cat’s Meow tweeter which sounds much more organic and natural.
Akitika preamps are now available. Akitika is discontinuing the GT-102 due to unavailability of the LM3886 chip. I hear a new amp will be designated GT-104, but product development is still continuing.Akitika amps and preamps are on waitlist until parts are again available. Contact them.
@xrk971 I have the LSA signature 50 - I have about 50 hours on them at the moment.
I removed the driver this morning and noticed no internal brace in the cabinet.
Do you think installing sheets of No Rez would improve this already amazing speaker even further?
Best Regards,
T- MM89
Best Regards,
T- MM89
