EL34 UL PP Transformer
Do you have any links to schematics using these?
Here are the schematics I have used. Attached also are test results of EL34 PP with TGL40 as pentode, UL and cathode feedback.
If you are interested in power supply schematics I have used, I can post those too.
Essential with JJEL509 (=PL519) is to have regulated screen and -Ug1 voltages.
  • EL34_6F12P_PP skema.pdf
  • EL34_6F12P_PP_UL skema.pdf
  • EL34_6F12P.pdf
    EL34_6F12P.pdf
Reactions: Marco audio
Hello,
Can you explain the cathod feedback please ?
Quad II works with cathod feedback ,but it's different (and i don't understand it too)
Hello,
comon winding for tube and rectifier filament ?...It looks strange, isn't it
They could build a 10v 0,6a winding instead of this on... Voltage network at home is 245v.
No, no common winding for tube and rectifier - that would NOT be good for the tubes, sitting with their cathodes at B+ potential!
I think either 6.3V for tubes, or 5V for rectifiers, not both.
I do not use it, and agree that it would indeed be better spent on eg this 10V buck/boost winding, a smaller power 6.3V winding, etc.
Hello ,
Yes , your power supply schematic interest me. Nice idea to use 6F12P for dynaco MK3.
Thanks a lot for sharing.
I will share soon my schematic,but perhaps in a other thread.
If you remember my first project was a gu50 PP.
But now the g807 PP project is already well advanced.
I owned a cheap strong a and strange pair of output transformers in a goodwill.
Have a look, windings mesures coming next,i must draw the schematic.
The iron is roughly the same size as the tgl 40/001 one.
Voici donc le schéma, je les ai branché sur le réseau 245v et mesure 10,1v ac en sortie. Z est 4,7k.
Comme vous le voyez il y a un autre bobinage qui donne 55v. A quoi ça sert ?
Please.
Yes it will work with 4R but you will have 2K instead of 4K primary impedance. The output power will depend on the tubes you are using and their biasing condition. The power rating of the transformer alone will increase but insertion loss will increase as well respect to 8R load because the primary impedance is halved while source impedance and DC resistance of the windings stay the same.
@jcalvarez, it might happen the contrary, lower distortion for the same output power but more distortion at low power. Likely more cross-over distortion. If it could work at all power levels, it will depend on the actual conditions. It could be adjusted or not, this will depend on the tuning possibilities one has with both the tubes and power supply.
