Another CFP output design attempt.
this is what a meander and a Bode diagram look like.
Reactions: de Ocampo
Thanks!
Now you only need a PJFET as bootstrap for the Siklai input to make the best LTMD input. 😉
(or BJT with needed accesories, as the Ampslab C200 Siklai LTMD)
By installing a jfet there, the thermal stability of the operating points of the circuit will deteriorate by about 20 times; to stabilize it, you will have to install a servo integrator. If you do not understand what I am writing about, then you can familiarize yourself with the FURY diagrams.
I do not recommend using a jfet in circuits without additional stabilization ...
I actually simmed this one..Ampslab offers a few interesting design for DIY.
Have you also seen the CFP output labeled 'Ultra Linear Design' from Silicon Chip? It uses a cascoded VAS.
Albert
I simulated and/or build several versions of that AMpslab C200Siklai. One normal, then with LTMD input, which sounds better and then, bootstrapped drivers for the output CFP and later also with cascoded VAS, but I ran out of copper to build the later...I do not want to hijack your thread...
M.
Time for some lesson, 🙂 I am trying to read the nfb depth in LTSpice bode plot. I just do not know if I am doing this right. 1 and 2 cursor data is shown in the small window. I will reflect here what the number reads at the arrow point.
Image one, x=21.483KHz y=28.877dB, 182.795°
Image two, x=5.205MHz y=28.979dB, 183.319°
Albert
M.
👍 It is OK M, we are speaking of CFP's.
Albert
I can not explain it but I did not like the sound of my TGM2 as much as I would have expected and I attribute this to the use of CFP in the input (an LTP input stage). Compared with the simpler LTP input of TGM1 it had more clarity and impactful bass but it was too harsh sounding for my taste. And it is a matter of taste, so you may have to try it for yourself.
If one, wanted to check on my Singleton.asc files, here it is. LTSpice will report errors and or unrecognized parameters in the log, this is due to the square wave vsource when not in use. You can simply delete the source, but I do think the errors in the log does not affect the results
I now simplified the input removing the other transistor, it now uses only twin pole compensation at VAS. (It is H2 dominant by the way so one cannot expect a very low THD numbers).
The only obstacle that keeps bothering me was that 'tilted' square waves, I suspect it now lies in the voltages and currents balance.
Albert
I am very glad seeing you in the thread.
Albert
